Question about Watches
FORGOT HOW TO CHANGE TIME ON OLD WATCH, AT LEAST 14 YEARS OLD BUT STILL WEAR IT EVERY DAY.
escapement
  • 2334 Answers
SOURCE: My Citizen Eco Drive watches stopped at exactly the same time
Visit www.citizenwatch.com
Choose Technical Support/FAQs/Select Topic/Eco-Drive recharging guide and follow the instructions.
Posted on Dec 18, 2008
escapement
  • 2334 Answers
SOURCE: watch goes slow when wearing
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Posted on Jan 07, 2009
  • 110 Answers
SOURCE: Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Posted on Dec 12, 2009
  • 10 Answers
SOURCE: watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Posted on Feb 23, 2010
  • 906 Answers
SOURCE: All my watches losing time
good day,
hope this link below will solve your problem.
watches
Posted on Jul 30, 2010
I have a navitimer world which i bought second hand a couple of months ago, but it seems to be losing time, it loses a minute or 2 a day, and every few days i need to reset the time,i wear it all day and...
Without seeing the inside works (movement) of your new (to you) watch and its parts, it's impossible to tell exactly what is going on, but no need to worry, as that's what competent watchmakers are for. Probably just needs a new spring, which wear over time due to many factors, including temperature, shock and corrosion. Basically, when you wind up any mechanical watch (whether automatic or hand-wound, regardless of age), you're tightening the spring which in turn is what powers up the watch (powering up the gears as it returns to its original position--i.e., unwinds, accuracy dependent thus on the spring among other factors). Sounds to me like it just needs a routine service, mechanical watches being no different than are automobiles, which require regular service as well. In the case of a watch, this will entail a cleaning, fresh oil and regulation, with old springs often simply swapped out for a new ones at that time by a watchmaker; routine services are a standard procedure which can be performed by any competent independent watchmaker, and don't cost a lot either. Most watch manufacturers recommend such service be carried out every 5 years or so, and while some can go longer (especially if not worn daily, same as a car when it comes to oil changes/service intervals), it's important to remember to service your mechanical time pieces which, if you do, will provide you with decades of reliable time keeping. All the best.
Sep 05, 2010 | Breitling Navitimer World 715 A24322 Watch
When I started wearing the watch it would stop at least once a day and I would have to pull out the reset time button, fix the time and push the button back in again to get it started. It happened 4 days...
If it's a quartz watch, replace the battery. If it's a mechanical watch, even a "self-winding" model, wind it manually - unless you're very active it needs a manual winding if you don't wear it all the time. If it's more than a few years old it may need cleaning by a watchmaker.
Apr 09, 2010 | Pulsar Bracelet PXQ502 Wrist Watch
My techno marine watch is not working. The battery was changed two years ago but the watch is only worn on special occasions. do you think it needs another batter. It is the diamond faced version.
That's right- your watch needs battery replacement. No matter you wear it every day or just once a year - battery life comes to an end in a two years time approximately. Expect the same all over and over again.
Rate me, plz.
Jan 07, 2010 | TechnoMarine Watches
IT IS RUNNING SLOW EVEN THOUGH IT'S BEEN WOUND.
If your watch is less than 2 years old then they may service it for free, and if it is that new I would take it back to point of purchase for assistance. Even though Rolex's are Chronometers they are not known for their ability to keep near perfect time. If you are losing only 6 seconds a day then you are still over 99% accurate and it does not really get much better than that (that means you may loose a couple mninutes a month. A watch winder that you set your watch in while not wearing can keep it spinning/ winding and therefore may increase accuracy.
If your watch is loosing a lot of time (half an hour a day) or if the watch is more than 5 years old, it likely needs some servicing. Oils can harden and thicken within your watch and this will affect the performance. Rolex recommends servicing your watch every 5 years or so to keep it in peak condition. A usual service entails a cleaning, oiling and regulating; this usually costs from $350 to $700 depending on where you go and if nothing else is wrong with your watch.
But again, if you are only loosing a few minutes a day, then your watch is still in good shape and I would not recommend paying the money to get it to work only a small bit better.
Oct 20, 2009 | Rolex Watches
Watch stopped running when not worn for days. turned crown 20 times per Raymond Weil manual, did not work.
Make sure you are turning the crown clockwise and stop winding when you feel the tension increase. Also, try wearing it for a day even if it is not runninr; the motion may be enough to get it going if it is an automatic.
There may be something more wrong with your watch.
If the RW is less than 2 years old you should be covered, they have one of the best warranties in the business.
If it needs repair and is older than 2 years, I would still send it to the RW repair center in NY to see what they can do.
Oct 17, 2009 | Raymond Weil Parsifal W1 watch
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
Jan 07, 2009 | Watches
Dec 18, 2008 | Watches
Watches Logo
15 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
