Question about Tilite ZRa Titanium Wheelchair
Ti lite mAnual chair. hub rubs on axle and i am not sure how to lengthen the axle to hold hub further away...
  • 280 Answers
The quick release axles on this chair have an adjusting nut on the outside end to adjust the length. The nut may have a disc cover on it for decoration. To adjust the axle length hold the end with the two balls on it with an adjustable crescent wrench set for the axle diameter and at the location of the balls. This way when you adjust the nut, the axle will turn until the balls contact the crescent wrench and the axle will stop turning. Turning the nut counterclockwise will lengthen the axle. All the nuts require a 3/4" wrench. Once you have made the axle longer you may need to put a washer between the hub and the axle receiver to keep the hub from rubbing.
In my experience, the hub may be rubbing because the camber tube is not even where the frame connects/clamps to it. Loosen the camber tube mounting bolts or clamps. Measure both sides and correct by marking the original camber tube position first, then adjust left to right for even spacing. Only adjust left to right do not rotate the camber tube since that will change the camber (unless you have zero camber). If you lengthen the axles this way check that the new adjustment allows the axle to lock in the camber tube. Tug on the wheel to make sure it is locked in the tube before getting in to ride. Hope this helps.
Posted on Nov 09, 2010
Front differential diagram
Looks like you have your answer. most toyota's I have dealt with were full floaters, no lock ring needed. good luck
Mar 31, 2014 | 1993 Toyota Pickup
1999 fuji mx480 rear wheel rubbing
sounds like it may be a couple things, this this is a five year old post, this is for other users. In your case the wheel may not be seated in the dropouts correctly, loosen the quick release or axle nuts and pull the wheel as far back in the drop outs as it will go and retighten. If it is still rubbing then the drop outs them selves are out of alignment. Most competent LBS's (local bike shop's) have a set of drop out H tools that are used to check front and rear drop out alignment and can be used for minor adjustment of the drop outs. In a more extreme case the frame could be out of alignment or one of the drop outs could have been welded incorrectly and the frame sneaked past the manufacturers quality control processes. When rebuilding your hubs make sure there is an equal amount of axle protruding from each side of the hub to insure that it is centered properly. Some hubs use 8, 9, or 10 bearings, as long as they all fit in the hub race without binding or overlapping (so to speak) you are ok and they are easy to loose. I use a telescoping magnet to extract them from the hub when I rebuild. Most LBS's will sell you new bearings, just take the old ones in and they will have a tool to measure the diameter to provide you with the right size. One more thing; there are standard drop out spacing sizes, measured on the inside faces of the drop outs, and depending on how many speeds your rear wheel has. 6-7 speeds is 120mm on older bikes from the 80's and before. Most bikes today have 135-145mm spacing to accommodate the larger gear clusters of 8,9,10,11 speeds.
Apr 19, 2013 | Fuji Cycling
My moms explorer- when she turns hard left or right she gets a rubbing sound like from the tires bit thats not whats rubbing. it sounds like the 4x4 is engaging. she has to back up about 15-30 feet to fix...
No fuse wont help, this sounds like the 4wd is engaged, the front axle hubs need to be checked or the front axle actuator may be stuck, there are a few things that can cause this problem and if its all wheel drive that makes things harder to check out, soory theres no easy fix without having it looked at.also make sure all the tires have the proper amount of air in them 35psi is good, hope this helps.
Jan 01, 2011 | 1993 Ford Explorer Limited
How do you remove the rotors from a 1991 honda accord?
Loosen both front wheel lug nuts and raise car and support on jack stands. Remove wheels and have a friend hold brake pedal down and remove axle nut. Use a chisel or screwdriver to remove stake on nut to axle edge. I use a 3/4 drive set socket and remove axle nut. Rent it from Autozone. Remove caliper assy and support with coat hanger or bungee cord to hold weight of assy off of brake hose. Remove Cotter pin and nut on lower control arm. Separate with ball joint fork and pull strut assy away to the side while pulling stub axle through and out of the way. Remove 4 bolts holding rotor and hub assy. on the inside of steering knuckle and separate. Now remove 4 bolts on hub's outer side and separate rotor and hub. You can use a bar or large screwdriver between wheel studs to loosen the 4 bolts.
Aug 04, 2010 | 1991 Honda Accord
2001 ford focus is making noise on right side axle?
You need to jack your car up and take a look at that side of your car. Inspect the axle, looking closely at the rubber boots on the axle (these are your CV joints) make sure they're not torn if they are then you'll need to replace the axle most likely because these boots hold grease which in turn keep the CV joints lubricated, once torn the grease escapes and the joint dries out. Also remove your tire and inspect your brakes, rotors, dust shields. look for anything that might be rubbing. Another possibilty is you could have a bad hub bearing on that wheel. This is a little more difficult to diagnose unless it's severly worn. If everything else checks good on that side. Driveyour car, preferably in a large open area like a parking lot in a straight line until you hear the noise then turn left and right, not sharply but just enough to shift te weight of the car, if the sound of the noise changes it's a good possibilty you have a worn hub bearing. Hope that helps, gl.
Jul 10, 2010 | 2001 Ford Focus
Changing cvc joints 1997 accord
replace the entire CV axles. Support vehicle with jackstands by frame. Remove front wheels. Remove axle nuts. Remove lower balljoint nut. Separate balljoint from nuckle by banging hard with ball peen hammer on knuckle on spindle assy. Remove outer tie-rod nut. Separate tie-rod from steering nuckle by bangin on nuckle with ball-peen hammer. Use long pry bar to hold lower control arm down while simultaneously pulling hub/spindle assembly away from vehicle and pushing axle through hub toward transaxle. Go under vehicle and pry inner cv joint away from transaxle while holding axle assembly.
Install new CV axle in reverse of the disassembly.
Feb 21, 2010 | 1997 Honda Accord
1998 ford ranger 4x4 Front Axle hubs will not engage
I found a website that explaned that you can remove the hub and dust cover, inside is a spring which holds the hub out, removing this spring and replacing the rubber dust cover and hub will lock your front hubs in continious. as is done on later models, This has worked for my 98 4wd
Dec 16, 2008 | 1998 Ford Ranger SuperCab
Hub noise
You have a bad wheel bearing, when you turn away from the bad bearing the wheel bearing is un-loaded and quiets down.
Nov 14, 2008 | 2000 Chevrolet Cavalier
Tilite ZRa Titanium Wheelchair Logo
206 people viewed this question
Top Tilite Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Tilite Health and Beauty Expert? Answer questions, earn points and help others
