Question about Yamata FY101-1A
I cannot find the SAE # on the Singer sewing machine oil. We have a dehumidifier that uses SAE 20 and would like to use the sewing machine oil we already have on hand. Thank you, Marsha
5 Suggested Answers
sweetpea5
SOURCE: Instruction Manual for Singer Concerto 3 sewing machine
i have this machine and would be glad to answer any questions for you
susan
Posted on Jan 07, 2009
  • 1116 Answers
SOURCE: hand held singer sew quick
Remove the plastic pin holding the bobbin (thread source) - careful to not lose the spring.
You may need a pair of pliers to get it loose the first time.
Press down on the edge of the bobbin so the pliers can grip the pin - lay a piece of material over the pin so the plies do not gouge the plastic - twist and pull.
Posted on Jun 01, 2009
  • 136 Answers
SOURCE: I need a manual for a Singer Scholastic Sewing
try order from linssewvac@hotmail.com
Posted on Sep 08, 2009
  • 139 Answers
SOURCE: please help..I own a prelude singer sewing
Instructions on oiling your hook (the only area suggested for the user to oil) is located on page 40 of your instruction manual.
Posted on Apr 16, 2010
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
Can i use a clear synthetic motor oil to lubricate my Singer industrial sewing machine?
Because I expect you are using it for home use I will tell you this. Users of this machine may have a mess from the oil pan. Take the oil pan off. A man I worked on began to use synthetic grease on a regular time frame such as 100000 stitches. This prevents the mess from the oil pan. It appears as a powder but will adhere to the gears. I wouldn't use synthetic motor oil because it doesn't stick too well. Anyway, this is only a suggestion. The nice thing about this is it comes in a spray can at Walmart
Dec 23, 2014 | Singer Sewing Machines
How to oil in singer sewing machine 2808c
some sewing machines are pre oiled some are not, if oiling is not
in the manual then call singer and ask them about oiling
the sewing machine
1-800-4-SINGER (1-800-474-6437)
Oct 23, 2012 | Singer Sewing Machines
How do I oil my singer 8280?
You oil the shuttle.
Page 40 of the manual shows where to oil.
Make sure to use clear sewing machine oil.
If you do not have a manual you can download (free) from Singer at this site - http://www.singerco.com/accessories/manuals.html
Apr 13, 2010 | Singer 8280 Mechanical Sewing Machine
Maintenance of Athena 2000 (Singer), specifically, cleaning and oiling
http://www.threadsmagazine.com/item/4731/preventive-sewing-machine-maintenance
http://esostarikaknitfo.blogspot.com/2007/05/how-to-clean-your-sewing-machine-101.html
These might give you an idea on cleaning and oiling your machine - I also use my vaccum cleaner sometimes- but very carefully.
Always use sewing machine oil - singer brand is good. - If you have pipe cleaners they are good to use on hard to reach places.
Feb 16, 2010 | Singer Sewing Machines
Is it safe to use WD40 oil to lubricate my singer 648?
Hi. No, don't use WD40 oil to lubricate your Singer. Use sewing machine oil--it's a whole different breed of animal than WD40 and won't hurt your machine. You can easily find sewing machine oil at Jo-ann's, Hancock's, or any other local fabric and/or craft store. It's not expensive, but repairing the insides of a machine gummed up from WD40 IS!
Good luck and let me know how this works.
Robbie
Jan 11, 2010 | Singer 8280 Mechanical Sewing Machine
Singer sewing michine model 3116, when sewing makes a
How long has it been since you oiled it? That may be all you need to do but be sure to use sewing machine oil
Dec 17, 2009 | Singer 3116 Simple
Carriage on singer ke 2500 keeps catching kneedles and yarn loops
take out your bobbin holder and see if there is thread clogged up inside the machine
Jan 23, 2009 | Singer 132QRFB Mechanical Sewing Machine
Open Questions:
Sewing Machines Logo
120 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Michael Kovalik III
Michael Kovalik III
Cleverer2
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
