Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
How do you test the ingition coil on a echo 16 inch chainsaw?
    Brigadier General:
  • 4,088 Answers
Remove the ignition switch wire from the module. Set the module pole gap by turning the flywheel magnets under the module poles, insert a thin business card into the gaps, and loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the gaps don't close up at any point. Test for a blue, snappy spark at a fresh plug gapped 0.020". If nothing or very weak, replace the module. Hope this helps!
Posted on Nov 08, 2010
I have a wt820 carb on an echo cs400 how do the fuel lines route
wt820-carb-echo-cs400-fuel-lines-route-u2zok31ofbeqiqkdplhepnij-2-0.jpg which is for the fuel line with the filter and which is for the primer bulb?
Nov 13, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My chainsaw has no spark, I have checked the spark plug and it works on another unit, i guess it may be the ignition, ho0wever as it is a small coil I have no way of checking. can the coil be simply...
Yes the coil can be tested. you would need to know the proper specs but with a multimeter you should be able to get a resistance value from your plug wire to ground. With my experience 10000 - 30000 ohms should allow it to run. If this is no help one common thing is your kill switch. A wire should run from the coil to the switch, if this wire is shorted to ground it will not run.
Dec 13, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
Echo chain saw 16 inch will not start
You need to play about with the timing adjustment.
You can adjust the timing by two different methods.
The first is to adjust the space on the spark plug.
The other is to adjust the gap between the contact, and the coil/magneto.
There ya go, FixedYa !))
Don't forget to rate, thanks.
May 09, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
417 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
