No sound on tv
When i turned on my tv this morning, no sound was coming out. It was fine last night and i cant understand why theres no sound.
Any ideas anyone?
Thanks x
  • 275 Answers
SOURCE: TV won't turn on
Unless you know Solid State Electronics, there is nothing you can do. At best, You could unplug the TV, remove the back cover, slide out the Circuit board, and check the fuses. They will be at the front of the Circuit board, left hand side. But in all likelihood, it is not just the fuses, the Power Regulator STR would also be short circuited (happens often in SONY TVs) and so it is best that a professional technician have a look.
Posted on Sep 27, 2006
  • 192 Answers
SOURCE: TV was Fine last night, this morning there is picture, but no sound
Since the you were vacuuming behind the set before this happened, I'm going to assume that you unplugged an input. Check the wiring, not just on the back of the set, but, on the back of the peripherals (DVD, Satelite, cable box, etc.) If wires are connected, then, take a component, such as a VCR or cable box and hook it up to the RF connector (AKA the cable connector) and run it on channel 3 or 4. If you have sound, then, you have a configuration problem and need to rewire your set. Hope this helps.
Posted on Mar 18, 2007
  • 1694 Answers
SOURCE: RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Posted on Oct 09, 2007
  • 4 Answers
SOURCE: RCA F36650 36
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor.
Posted on Jan 05, 2008
SOURCE: ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Posted on Nov 10, 2008
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 26 HDTV LCD Monitor
Probably a burnt fuse, have it serviced.
Feb 21, 2008 | Televison & Video
Toshiba 27D46 will not come on?
It may be a fuse. But something else may have blown the fuse. I would check the circuity of the power supply.
Oct 27, 2012 | Toshiba Televison & Video
I turned off the tv last night like every night but this morning there was sound but know picture. I checked all the cords/cables I unplugged and plugged them in but nothing. I cant even get the menu to...
What is the make and model of your tv? If this is an lcd or plasma, is there a backlight that comes on when you press the power button? If this is a dlp tv, do you see the lamp light from the back of the set? If you give me make and model I can download service manual to give you more informed information.
Apr 03, 2011 | Televison & Video
My 46" SONY LED has no sound coming out now.
Hi this sounds very much like a dry or bad solder joint probably on the power supply PCB, if you have the necessary soldering skills and a magnifying glass you maybe able to fix this yourself.
The picture below shows an example of what a dry joint(s) looks like, if you are able to solder and understand the risks in taking apart your TV you could save yourself a good few bucks!
Always make sure the TV is unplugged and please be aware that voltages can still be stored even when the tv is turned off, if in any doubt or you are unsure about attempting a repair please consult a qualified TV technician.
Hope this helps
Midge.
Feb 10, 2011 | Sony BRAVIA XBR46HX909 46 in. 3D HDTV
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Mar 25, 2010 | Insignia 42" LCD Flat-Panel HDTV
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
