Question about Keurig Elite B40 Coffee Maker
All the lights are blinking on my keurig coffee maker?
The lights on my keurig are blinking and will not turn off. What does this mean
Posted on Jan 09, 2011
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Posted on Jun 14, 2009
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
SOURCE: blinking lights
let it blink for about 15 minutes, then adjust each one of the settings, then turn it off and back on, for some reason it stops flashing and will work. Warning, after doing this for about a week, mine now has no power at all. It is plugged in and the outlet works and there is no power going to the machine, it is not even a year old!
Posted on Aug 15, 2010
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 14, 2010
My keurig coffee maker lights are blinking all the time but nothing is happening
Handle not compressed all of the way into the Kcup. Use pressure.
Sep 21, 2012 | Keurig Elite B40 Coffee Maker
Every light on my machine is blinking and not brewing coffee
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 01, 2011 | Keurig Elite B40 Coffee Maker
After blue light blinks, and button is pressed, no water flows into the cup. What to do????? Janet
heatman101
Jul 07, 2011 | Keurig B60 Coffee Maker
Get message prime and blue light is blinking and reservoir is full
heatman101
Jun 15, 2011 | Keurig Platinum B70 Coffee Maker
Brewer not filling complete cup, then fill water and small cup lights blinking at same time continuously
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig Elite B40 Coffee Maker
Getting the message "prime" and blue light is
heatman101
Apr 15, 2011 | Keurig Platinum B70 Coffee Maker
All lights blinking on keurig elite will not brew
heatman101
Jan 07, 2011 | Keurig Elite B40 Coffee Maker
My keurig says Not Ready and won't brew
Push the 2 buttons next to menu at same time then press menu. Wait for keurig lights to blink then release buttons. You just reset your keurig. Turn on and enjoy.
Oct 14, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
8,044 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
