Question about Mitsubishi WD-73827 73" HDTV DLP TV
My picture does not show any lower wording the picture is cut off. I even adjusted the V setting from 33 to 0 and does not correct the picture.
    Sergeant:
  • 252 Answers
Your problem is not in your settings. You have weak capacitors in the the vertical section or the high voltage section of your TV. The back of the set will have to be taken off and speacial equipment will have to be used to troubleshoot it. (multimeter with capacitance check). Check for weak caps and replace with the same farad rating but slightly higher voltage rateing caps. This will fix your problem.
Posted on Nov 09, 2010
The picture on my Hisense 40 tv has been zoomed out. Sides of picture and words are cut off. how can I fix this?
Go to Settings or Menu and look for the words 'Aspect Ratio'. Adjust it there.
Check the link for info.
Google
Jan 04, 2017 | Hisense Televison & Video
My tv has several white horizontal lines running across the top of the tv screen the tv brand is an Insignia SDTV and its an older tv what can be done to remove these lines?
This is a retrace blanking problem. Probably, the Vg2 voltage is too high, so the cut-off point from the picture tube is not correct. Try to lower this voltage. On most common flyback trafo's it is the lower adjusting screw (plastic kind of button) which is used to set the Vg2 voltage. Turn it a bit CCW until the white lines disappear.
Jun 14, 2014 | Televison & Video
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
Watching espn hd, the picture cuts off on one side. How do I adjust this? The ESPN bug is well within the border in the right hand lower corner, but a chart that comes on perodically during play...
There's a resolution/aspect ratio you can adjust in the picture menu, or straight from the remote. Choose the size you want on ESPN that best fits the picture while watching it.
Jun 16, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Verizon Voyager, touch screen isnt working correctly, its pushing buttons with out me even touching the phone. it seems to really like to click on my short cuts and text msgs. it gets worse every morning...
go into your settings.go to the setup phone section,then go to where it says touch screen or pen adjustments..im sure how it will be worded but you can adjust the sensitivity of your touch screen
May 26, 2010 | Cell Phones
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Cannot see words at the bottom of the screen.
i think you should call them first, time warner, i don't see any problem with your unit.you try evrything and only this time warner is the only problem.they are sending incompatible tv formats.
May 31, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Yardman riding mower cutting uneven
You need to park on a level area and lower the deck to it's lowest setting and adjust the deck with the large butterfly nuts on each side,just under the foot pan,just loosen and let the adjusters fall into place,Tighten back up and it should be set.
May 15, 2009 | LG enV VX9900 Cellular Phone
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
