Question about Jenn-Air WW27430P Stainless Steel Electric Double Oven
The display at the top of the two ovens has become almost illegible. The time of day is still visible but temperature and time left to cook is either illegible or barely legible.
  • 3 more comments
  • jmcarnahan Nov 09, 2010
    This is a WW2743.
    This is the Unit indicataed. Please see if you can find a part for me John Carnahan
    The oven # is corfect. Please find a part for me. John
  • jmcarnahan Nov 15, 2010
    I purchased the part you indicated would fix my problem. All the hookups fit but I cannot perform certain things. For example I can turn an oven on but not off.
    The old part number shows: Robertshaw / 53-00173-02 / HD404318C89S / 0406 Japan. The new number is identical except the HD404318C89S has an additional V following S, What appears to be the date 0406 on the old part is now 0712.
    Hope to hear from you soon. John Carnahan
    President:
  • 2,777 Answers
This would indicate the actual display of your oven is failing, it does happen, sometimes they last for 30 years, sometimes as little as a year...
Is this a Jenn-Air WW27430P as indicated?
Please reply and confirm and I can find the part for you.
Thanks
Tim
Posted on Nov 08, 2010
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Display reads " -F3-
    Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
    Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Can I clean a TruTemp oven with soap and water without ruining it?
    Yes you could clean it.
    Check few details :-
    t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
    How to self clean
    If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
    The oven door must be closed and all controls set correctly for the cycle to work properly.
    Before a Clean Cycle
    For the first self-clean cycle, we recommend
    venting your kitchen with an open window
    or using a ventilation fan or hood.
    Remove any broiler pan, broiler grid, all
    cookware, probe and any aluminum foil
    from the oven—they cannot withstand the
    high cleaning temperatures.
    NOTE:
    If your oven is equipped with nickel oven
    shelves, remove them before you begin
    the self-clean cycle.
    If your oven is equipped with gray
    porcelain-coated oven shelves, they may
    be left in the oven during the self-clean
    cycle.
    Soil on the front frame of the range and
    outside the gasket on the door will need to
    be cleaned by hand. Clean these areas with
    hot water, soap-filled scouring pads or
    cleansers such as Soft Scrub®. Rinse well
    with clean water and dry.
    Do not clean the gasket. The fiberglass
    material of the oven door gasket cannot
    withstand abrasion. It is essential for the
    gasket to remain intact. If you notice it
    becoming worn or frayed, replace it.
    Wipe up any heavy spillovers on the oven
    bottom.
    Make sure the oven light bulb cover is in
    place and the oven light is off.
    IMPORTANT: The health of some birds
    is extremely sensitive to the fumes given
    off during the self-cleaning cycle of any
    range. Move birds to another well ventilated
    room.
    NOTE: Use caution when opening the upper
    oven after the self-clean cycle has ended.
    The oven may still be hot.
    How to Set the Upper Oven for Cleaning
    On models with Gas/Control Lockout,
    touch and hold the Gas/Control Lockout
    pad for 3 seconds to turn it off.
    NOTE: The surface burners must be turned
    off prior to the self-clean start time.
    If your model has a latch, latch the door.
    Touch the Self Clean pad.
    Using the number pads, enter the
    desired clean time, if a time other than
    4 hours is needed.
    Clean cycle time is normally 4 hours. You can
    change the clean time to any time between
    3 hours and 5 hours, depending on how dirty
    your oven is.
    Touch the Start pad.
    On models without a door latch, the door
    locks automatically. The display will show
    the clean time remaining. It will not be
    possible to open the oven door until the
    temperature drops below the lock
    temperature and the LOCKED DOOR
    light goes off.
    The oven shuts off automatically when the
    clean cycle is complete.
    When the LOCKED DOOR light is off,
    slide the latch handle to the left as far
    as it will go and open the door. If your
    range does not have a latch, the door
    will unlock automatically.
    The words LOCK DOOR will flash and
    the oven control will signal if you set
    the clean cycle and forget to close the
    oven door or forget to latch the door
    on models with a latch.
    To stop a clean cycle, touch the Clear/Off
    pad. When the LOCKED DOOR light goes
    off, indicating the oven has cooled below
    the locking temperature, unlatch the door
    (on models with a latch) and open the door
    How to Delay the Start of Cleaning
    Make sure the clock shows the correct time
    of day.
    the door.
    desired clean time.
    Touch the Delay Start pad. The earliest
    start time you can set will appear in the
    display.
    Using the number pads, enter the time
    of day you want the clean cycle
    to start.
    locks automatically. The display will show the
    start time. It will not be possible to open the
    oven door until the temperature drops below
    the lock temperature and the LOCKED DOOR
    light goes off.
    The words LOCK DOOR will flash and the
    oven control will signal if you set the clean
    cycle and forget to close the oven door or
    forget to latch the door on models with
    a latch.
    pad
    (on models with a latch) and open the door.
    After a Clean Cycle
    You may notice some white ash in the oven.
    Wipe it up with a damp cloth after the
    oven cools.
    If white spots remain, remove them with a
    soap-filled scouring pad and rinse thoroughly
    with a vinegar and water mixture.
    These deposits are usually a salt residue
    that cannot be removed by the clean cycle.
    If the oven is not clean after one clean cycle,
    repeat the cycle.
    You cannot set the oven for cooking until
    the oven is cool enough for the door to
    unlock.
    While the oven is self-cleaning, you can
    touch the Clock pad to display the time
    of day. To return to the clean countdown,
    touch the Cooking Time pad.
    If the shelves become hard to slide, apply a
    small amount of vegetable oil or cooking oil
    to a paper towel and wipe the edges of the
    oven shelves with the paper towel.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
    Lost my manual for chef condor integra oven - need to check auto functions and how to set them
    For TOuch Control oven:
    1. Press Finish Time touch pad
    2.press ^ touch pad until clock displays the required am or pm finish time.
    3. Press Cook Period touch pad.
    4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
    5. Press Automatic touch pad.
    Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
    7. Turn oven thermostat to desired setting.
    8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
    10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
    For Multifunction oven:
    1. Set time of day.
    2. Turn Function switch to Finish. 0.00 will be displayed.
    3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
    4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
    5. Turn Function switch to Auto. The automatic programme is now ready to use.
    Turn upper oven thermostat to desired setting.
    If keep warm function is required, turn function switch to Cook (optional)
    Happy cooking!
    Jun 14, 2009 | Ovens
    F2 error, both ovens stopped working
    F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
    Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
    Jenn-Air WW27430P Stainless Steel Electric Double Oven Logo
    367 people viewed this question
    Top Jenn-Air Ovens Experts
     Fix Your Board
    Fix Your Board
    Dan Webster
    Dan Webster
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
