Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Want to get a manuel for lawn mower, for lt1046, i have to replace one gear, a belt, and lawn mower wheel.
  • 12,061 Answers
Http://compare.ebay.com/cub-cadet-lt-1042-1045-1046-1050-gt-1222-service-manual/like/330478537005
There you go you better be quick though it closes in a couple of hours.
I can only find pay for ones, in any case so this maybe your best bet.
Posted on Nov 08, 2010
  • 32 Answers
Use the following link to download the manual in PDF format for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
  • Philip Norris
    Philip Norris Dec 07, 2010
    Did this help you out?
1028 rear engine riding lawn mower model # 927046 is not moving when in gear. Was told I needed a drive box unit for it
check to see if the key in the axle is in place or if you put it in gear the axle turns in the wheel . is the pulley in place and not loose. the belt is good you said. but the pulley may be stripped. (axle key, belt, pulleys, or belt off of pulley)
Nov 19, 2016 | Garden
Replace belt
if you take the deck of first you can see it better take circlip off bottom of steering gear lift steering wheel up a little bit and fit new belt
May 07, 2013 | Garden
Have a toro lawnmower mdl #20012 front whell drive. When I engage the system it makes a grinding sound & when I take the weight of the wheels it runs smooth. Seems like a gear but not sure. Could it...
Some have gear in each wheel. Remove wheel see if plastic in wheel is worn out. Home Depot or Lowes carries some replacement wheels. Lawn mower repair shops sell them also.
Aug 22, 2012 | Toro Power Lawn Mower
Cub Cadet LT1046 shutters when under a load, climbing steep hill
i would check the belt for oil or slipping the check rear axle fluid level
Mar 27, 2012 | Garden
Cub Cadet Problems
Sorry it has taken so long to reply, busy time of year. It is very possible the wheel bearings are going bad, but you should notice it at all times. Some lawn and garden tractor front wheels are that way for steering. The John Deere lawn tractors are toed in for example. Wouldn't hurt to check the wheel bearings as well as the spindle bearings. They should all be greasable, and if the issue is better after greasing, you have found your problem. If not, let me know and I will see what else I can come up with, Daniel.
Oct 23, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
1,302 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
roeb
Marvin
Marvin
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
