Question about Husqvarna Garden
I have an old husky its about 31 years old it runs and cuts fine but the chain doesnt stop spinning when its just idling. is there a way to fix this or does it always do this because its so old and doesnt really have any safety features on it
    Brigadier General:
  • 4,088 Answers
Just turn the idle screw CCW until the chain stops moving. If you go too far, the engine will tend to die at idle. Good luck!
Posted on Nov 08, 2010
Testimonial: "thanks "
Own a 450 husky saw tool less and cut 4or5 blocks of wood chain completely loose im tighting goof buy loosens.
Hi Dale:
Here's the process that I use. Have a look and see if it works for you.
1) Slacken the nuts that clamp the bar to the saw.
2) Lift the tip of the bar and hold it up through the next 2 steps.. This will put the most slack to the chain.
3) Use the adjuster screw to tighten the chain until it will barely clear the groove when you lift it at the centre of the bar.
4) Still holding the tip up, tighten the nuts that you loosened at step 1.
Should work fine now.
Here's a tip. It never hurts to occasionally clean the bar and chain assembly. Dismantle it, keep the parts organized unless you know where they fit. Use solvent to loosen all the grunge. I like to use air to blast it all off.
The ONLY way a chain can loosen if the bar is solidly mounted is if the chain stretches or "wears". Make sure the chain oils system is functioning, and that the chain is properly sharpened so that it does not over-heat.
My old husky 266 just keeps running!
Cheerfuls!
Nov 11, 2015 | Husky Garden
2 year old TS410 no power recently, was serviced , correct mix but dies when pressure comes on ,blade stops, starts fine and runs idle fine-tom
Hi Thomas its probably had its high/low screws reset and whilst it runs fine on the bench under load its running weak try unscrewing the high screw out a half a turn
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Jul 12, 2010 | Makita DCS640120 Commercial Grade 20Inch...
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain spins when not cutting
Sounds like a clutch issue but if the chain is spinning once you start the unit you'll need to do some adjusting to your carb.
Apr 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 345e
I have a model 435 Husky that had the same hard-to-start problem--warranty service replaced the carburetor and it seems to work ok now. The chain that continues to turn can be fixed by turning the idle-speed screw (not the H or L jet screws) CCW a small amount until it can be accelerated then dropped back to idle to quit driving the chain. Hope this helps!
Apr 05, 2010 | Husqvarna 450 e-series 18" Chain Saw
Want a manual in English for 317EL chain saw
I apologize, I was short. Husky is my forte, and this one is my first dead end. You can go here for an IPL or OM for every Husky I have ever seen:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Husqvarna International has no 317**. There is a 316E. I downloaded and opened the IPL (using instructions above) for a 2003-08. There are only 2 logical parts that can cause a jam on a 316:
Detail B, on the right end of 508 04 36-42 (motor), is a spiral cut gear, not listed separately.
Detail D, 508 04 37-02, a second spiral cut gear.
It appears the right side of the motor housing is held in place by 7 fasteners. Removing them should provide access and allow inspection of any gear train. It will also likely void any warranty. Good Luck
Lou
Feb 02, 2010 | Husqvarna Garden
25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
You might read this thread
http://www.arboristsite.com/showthread.php?t=110858&highlight=husky+266
I searched for "Husky 266" and got many positive hits. She is a respected machine.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9f5525102886abf488256b52001a33af?OpenDocument
HTH
Lou
Oct 16, 2009 | Husqvarna Garden
Garden Logo
95 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
