Question about Linksys WRT300N Wireless Router
My linksys WRT300n doesn't work at all and all the light are on and it is only connected to power source, what can i do?or what are the light indicating?
  • 38 Answers
Try to reset the router while it's and release the reset button after 30 seconds . (Use a pen) . Let me know if it's working. Add me in skype , my english_valet or yahoo ronaoclarit so that I can help you.
Posted on Nov 08, 2010
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
Power light is dim and the 4 ethernet connection lights are bright green - even without a cab. Linksys WRT300N
First try unplugging it for about 45 seconds. Then plug it back in.
If this does not fix the problem try to reset it via the reset button on the back and see if that fixes the problem. This will make your network un-secure and you will have to add a new pass phrase.
Let me know if this solves the problem.
Mar 27, 2011 | Linksys WRT300N Wireless Router
My wrt300n power light does not come on when trying to reinstall my wireless
If the power light on your router wont come on , there are 3 possible reason for that:
The power outlet where the router is connected can be bad so what you can do first is to connect the router on a different power outlet and check if same problem.
The power adapter of your router is bad , so if you can try a different power adapter that will be good.
The router itself is bad after you tried those steps and still wont power on , so if the router is still under warranty better have it replace of call Linksys support via this number 800-3267114.
Sep 09, 2010 | Linksys WRT300N Wireless Router
Lost power on my WRT300N router. Power came back and now the power light is weak and all 4 port lights are on.
I had the exact same indications after a utility power spike.
Quite by accident, I discovered that the power supply to the WRT300N when fully seated into the router causes the lights (and the router!) to malfunction in this manner.
I pulled the power supply connection out gradually and the power light began to flash. Pulling the power supply even farther out eventually caused the power light to shine solid.
I don't know if this is a random manufacturer problem with just my WRT300N (V1.1) or if others may have a similar defect, but it's certainly worth a try!
Good Luck!
May 18, 2010 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
WRT300N dosnt connect
if your connection (isp) is CABLE you will need to clone the mac of the main computer.
For cable connection verify what computer can go online with your modem, once you know the main pc connect it to port one, access the routers setup page by typing 192.169.1.1 then locate MAC ADDRESS CLONE in line with basic setup. enable it click the macclone button then save settings.
connect your modem to the internet port on the router, do a power cycle on the modem and router.
then check the status tab on the linksys setup page if you have numbers on the dns it should be online.
Sep 12, 2008 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
416 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
