Question about Panasonic Televison & Video
When tv is turned off, it will not turn back on unless you leave it off for a number of hours. The light in the front will flash. Have to unplug from outlet.
  • hopeandjim4 Nov 09, 2010
    Thank you very much for your help.Very much appreciated!
  • Panasonic Master
  • 12,061 Answers
This is a fairly classic power supply shutting down problem, you see there is a faulty component(s) inside the set, now when it turns on, this part becomes overheated, and fails, subsequently, the protection circuitry in the switch mode power supply, "Senses" this "Fault" and Shuts down the set, to avoid a fire and explosion or both. Now when the set/component cools down, the set no longer "Senses" any fault, and allows the set to start up again, only to have the "Fault" reappear, and be shut down again.
The best thing to do, is get it looked at by a professional, it will save you time and money in the long run. Simply contact the manufacturer and ask for a referral to an authorised service center, here ask for a 'Quote" before allowing any repair work to be undertaken.
Posted on Nov 09, 2010
I have a samsung hcj552w rear projection tv. Every time the power goes out the tv will not turn back on unless I unplug it for a week or 2. When the power goes out then it comes back on just the red...
Replace the STK ICs,STK392-020 they are big black ICs and will have Part Number on them.Also CK the Low Ohm resistors in front of ICs. Mats Electronics has ICs 1-800-628-1118
Oct 29, 2010 | Samsung HCJ552W 55" Rear Projection...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Red light keeps flashing tv will not turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 30, 2009 | Toshiba 57H82 57" Rear Projection...
Mitsubishi WS-55807 Won't Turn On
The TV is on protect mode. The clicking sound is the protection switchthat keep turning the TV off to prevent further damage, this happenswhen a fault had been detected.
Alsoensure that the fault is not coming from a faulty receiver box sendingbad signal, check if you get same problem with no receiver boxor dvd connected.
If that does not work, and you keep having a flashingled on front of the TV, and tv turning off by itself after a while,that indicates a fault condition.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, startingthe flashing light.
Common faultsthat can occur are a blown capacitor on power board, aconvergence IC has blown, or a fault on Digital board.
Check alsothe video cable or any external connection cable, if the cable is shorting, or the connector is bad, youcan get same flashing state because of the video cable.
If you want to DIY you find parts here,
Feb 28, 2009 | Mitsubishi WS-55807 TV
Toshiba cz32v51power light flashes, with no picture
That means that an internal error had been detected, and now the TV is on protection mode.
To start unplug the power cord for ten minutes, and see if the TV restart.
If it does not try leaving the set unplugged for longer, let say two hours.
If still no luck call the number listed on the user manual, as the TV has an internal fault, and must be repaired by a technician.
Jan 14, 2009 | Toshiba CZ32V51 32" TV
Blinking timer red light on jvc tv, no other functions
Dec 27, 2008 | JVC AV-32230 32" TV
Toshiba 46H84 tv turned off light blinking
Sep 17, 2008 | Toshiba 46H84 46" Rear Projection...
Blinking power light TV doesn't turn on
Aug 02, 2008 | Toshiba 32A42 32" TV
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Televison & Video Logo
446 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
