Question about Xerox Phaser 8500/DN Printer
Codes? I was told i needed to reset my codes because i have a error code on my screen, but it wont let me access any menus it just diplays the error code.
  • 1 more comment
  • hamsden Aug 25, 2008
    Have phaser 8500/DN with error code 13,264.42:5414 it will not let me get past this stage.
    Reply's to Hamsden@gmail.com
  • diane szczesniak May 11, 2010
    What error code are you getting?
  • 3 Answers
According to an online PDF document I downloaded, the 13,264.42 error code means "The printhead reservoir heater got too hot." Not sure what to do to fix it, but first thing I would ask is does your printer sit in a hot sunny window, or is it in a badly ventilated cabinet or space so that it doesn't get adequate cooling? This kind of printer generates a good bit of heat from time to time.
Document available at https://www.office.xerox.com/partners/products/Phaser8500/SQRG/03_error_codes.pdf -
Posted on Oct 15, 2008
My 2006 vw jetta tdi lost power and died wont restart am told need code to restart but dont have right code
You will have to have the fault codes read by a code reading machine . That will tell you why the engine stopped. I am suggesting that you check to see if the cam shaft is turning when you try to start it as the timing belt may be broken. Repair/replace items listed by the codes -reset the CPU with the code reader
Jan 08, 2014 | 1998 Volkswagen Jetta
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
Our dog ate our remote control. Is there a code we can use to reset with a generic remote, as we need to reset for some channels
Well the reset on your dog probably won't work so it may eat another remote.
On the tv when you use a universal remote you enter a code for the remote. this lets it talk to the tv and should give you the same access to menus ie setup as the original. I don't see a tv model but when you get the universal it will have a list of all the codes. You just look up your manufacturer and then look for your model and enter the code. There may be a few codes per model so you just have to try each one until it works. Unfortunately for some off brand tv's the codes don't work but they are quite good for most. Your other alternative is of course getting a oem replacement.
And even with out a remote you can usually access the menus by pushing the buttons on the front of the tv. Its slow rather frustrating but should work if nothing else.
Mar 04, 2011 | Televison & Video
2002 chrysler voyager check engine light came on took van to dealership they told us it was the hoses. We bought brand new hoses all three and changed them. The light wont go off it still says that the...
On these vans the light will stay on untill it is reset. You need a OBD 2 scanner to reset it. You can take it to the dealer and have them do it but they will probably charge you like $130. The best thing for you to do is check with an auto parts store. They normally have a scanner on hand and will turn it off for you free of charge. Advance and Autozone I know pretty much have a scanner at every store.
Nov 03, 2010 | 2002 Chrysler Voyager
Need to the motorola ming a1200e master reset security code
my ming calibration screen wont open due to the fact I cannot access my main menus on top...so how can I get the calibration screen to open to claibrate this phone?
Jul 20, 2010 | Motorola Mobility A1200
Master reset codes for Motorola MD61 handsets
Remove the spare battery (if any) and handsets from the base station.
Navigate in the menus to the "base settings". Your screen should say "ringer volume, ringer melody, keypad tone, tone/pulse, ..."
Punch in the reset code (including the stars): **335782
Wait for the phone to restart itself (about 5 seconds).
Re-register all of your handsets.
Dec 15, 2009 | Motorola Mobility MD681 5.8GHz Digital...
Whirlpool gas range m#SF114pxsq1 diplays an F1 error code
HI. This is a basic Electronic Range Control Board failure code. I would advise to try a hard reset. This may correct the fault, if the damage is not severe. Simply unplug, or shutdown the appropriate circuit breaker for five minutes. After the five minutes have passed, kindly re-introduce power to the unit once more. Try to preform a baking cycle. if the code continues to illuminate during the attempt to operate the range, simply replace the main electronic control board(ERC or Clock).
Nov 16, 2009 | Kitchen Ranges
Need codes to access TV menus
The solution relies with the remote. press the menu button and use the +/- buttons beside it instead of the volume or channel buttons. This TV was at a work camp in northern Alberta and the instructions were not available. Hope this helps others who do not have instructions available.
Apr 18, 2009 | Toshiba 13A25 13" TV
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Xerox Phaser  8500/DN Printer Logo
232 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
