Question about Creative Labs Gigaworks S750 Computer Speakers
Audio control pod
When I turn my Gigaworks s750 on, the green LED on the subwoofer comes on, but, the audio control pod stays off. None of the leds come on.
It was working perfectly all the time until I pressed the standby/power button and then all the red LEDs went dead. Omly the green LED on the subwoofer stayed on. I checked the wiring connections and it seems to be correct.
  • 2 more comments
  • boss_time Sep 21, 2008
    same problem as above please help
  • ieetginx Sep 30, 2008
    identical
  • Anonymous Mar 18, 2009
    Hi ,
    WOW Ihave the same issues, All i want to do is buy the control pod can anyone help ?
  • Anonymous Mar 23, 2014
    subwoofer dead
It may be that your led (the one that dosn't come on) may be dead, this will stop functions. these controllers are very cheaply made, even worse if you have the 7.1 surround sound p7800!
Posted on Aug 24, 2010
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Posted on Jan 25, 2010
SOURCE:
My gigaworks s750 powers up and lights, but no sound
Hi, have you find any solution? I got the same problem. Can you please email me. mtlmw@hotmail.com. Thank you
Feb 26, 2012 | Creative Labs Gigaworks S750 Computer...
I have a Gigaworks 750, the Audio Pod is not working, however, there is power going to the subwoofer though the power light is flickering. Hope you can help me in solving the problem. Thanks
I did fix this problem and the whole bunch of other ones with the s750 system.
"light is flickering" is a very common! It shows that there is a problem with STANDBY power supply:
1) Yellow glue became conductive (needs to be completely removed)
2) Capacitor malfunctioning C61 (68uF 450)
3) mine had TH1 cracked (replaced from PC power supply) and D9 diode.
If this successfully fixed, you will be able to get 2nd stage power supply on (Relay or power on button)
If you will have problems there, there is a whole bunch of test needs to be done (capacitors, IRF740 etc.)
Aug 29, 2010 | Creative Labs Gigaworks S750 Computer...
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
No audio, no indicators but blinking green LED by power switch.
Replace elco C61 (68uF/450V) ; it is empty or almost empty.
Also remove the dark-brown glue carefully. The glue turns from light to dark brown by heat and becomes conductive (some Mohms)
www.tvman.nl
Jun 25, 2009 | Creative Labs Gigaworks S750 Computer...
All I need is the control pod for the Gigaworks S750
I had an extra one but I sold it. According to creative labs they do not sell any replacement parts for the speaker systems. The best suggestion that I can give is to check craigslist and ebay for the control pods.
Dec 13, 2008 | Creative Labs Gigaworks S750 Computer...
Audio control pod seems dead
You can see about getting a new control pod from ebay or craigslist but the problem is more likely inside the subwoofer. Below I have pasted a link to a forum thread about fixing the Gigaworks S750 systems. There is not much information there about control pod problems but at least the people on the thread will help as much as they can. If you are not familiar with electronics then some of the people on the forum thread can help if you are willing to ship the subwoofer box to them.
http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=1
Nov 09, 2008 | Creative Labs Gigaworks S750 Computer...
Sub has died overnight
Change the fuse - located at the 220V input. Use a knife ti release it. Then the system will work again.
Oct 08, 2008 | Creative Labs Gigaworks S750 Computer...
Shuts off after playing music
i had the same problem, apperantly creative made an error making the hardware for the subwoofer, and put in an mos-fet with to little resistance, i called creative and gave them the serial number behind the subwoofer and they sent me a new one that hasnt acted up yet.
Jan 13, 2008 | Creative Labs Gigaworks S750 Computer...
Control pod
Double check the connections, if the connection for the control pod is good then something is wrong inside. I would say most likely thing would be a problem on the power supply inside the subwoofer box.
Nov 29, 2007 | Creative Labs Gigaworks S750 Computer...
A mess!
pls check your audio cable conection. bye
Sep 11, 2007 | Creative Labs Gigaworks S750 Computer...
Creative Labs Gigaworks S750 Computer Speakers Logo
1,312 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
