Do you know how to resolve an I/O Device Error on a Toshiba Satellite P505-S8980 with Windows 7 Home Premium?
  • 7,733 Answers
Do you know how to - fix-io-device-error-200x200.jpg Fix an I/O Device Error Columbus Administrative Services Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motorlike force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else.
  • Access "Control Panel" from the Start menu and then choose "Performance and Maintenance."
  • Click "System" and then go to the Hardware tab and click on "Device Manager."
  • Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; proceed to Step 4 to enable it. Otherwise, go to Step 5.
  • Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown, proceed to Step 5.
  • Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown, proceed to Step 6.
  • Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
  • Posted on Nov 09, 2010
    Need activation key microsoft windows vista home premium
    go to isohunt.com and get a serial key from there
    May 07, 2013 | Toshiba Computers & Internet
    I recently got a toshiba satellite computer and it has no hard drive and i dont know what i need to do next. i know i need drivers and such and recovery discs, but where can i get them and everything?
    This model Toshiba Netbook came with a 240Gb hard drive and Windows 7 Home Premium (64bit)
    You can view the full specs from this WEB site.
    http://us.toshiba.com/computers/laptops/satellite/L450/L455-S5046/
    You can download theRecovery CD and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
    Aug 06, 2011 | Toshiba L455-S5046 (2500470) Netbook
    I have a toshiba P505 S8980 after a restart it wouldn't start in windows7 only had black screen with flashing underscore in top left flashing. ctrl alt + del just restarts to same ,i get choice of f2 +...
    Is Windows failing to boot?ust do the following.
    * Boot up the PC from your Windows installation disk.
    * Select the "Repair your computer" option
    * Select "Command Prompt"
    * Input "bootsect.exe /nt60 SYS /force" (without quotes)
    * Restart the PC
    Dec 22, 2010 | Toshiba Computers & Internet
    Toshiba satellite P505-S8980 laptop "A
    Solution 1) Set the system cooling policy to "active"
    Windows has two approaches to fan control - "active" or "passive". The default option is passive, but if you switch it to active instead then the fan will turn on more frequently. You can do this by following these steps:
    1. Left click the battery icon in the bottom-right corner of the screen (See image)
    2. Left click More power options (See image)
    3. Click Change plan settings next to the Balanced power settings (See image)
    4. Click Change advanced power settings (See image)
    5. Click the + next to Processor Power Management (See image)
    6. Click the + next to System Cooling Policy (See image)
    7. Change Passive to Active for both Plugged in and On battery (See image)
    8. Do the same for any other modes you use, such as power saving mode
    9. Restart the computer
    Solution 2) Keep Toshiba PC Health Monitor open
    Some of the comments below sing the praises of PC Health Monitor. Apparently, the laptop fan will work harder when PC Health Monitor is open.
    PC Health Monitor is already preinstalled on Toshiba computers. To open the program, just press the Windows key to open the Start menu, start typing "PC Health Monitor", and the program should appear in the search results. Click on it to open it.
    Apr 07, 2017 | Computers & Internet
    Owners manuel for Toshiba P505-S8980
    Hello
    OK, you will be able to download the requested manual at the link below.
    Click HERE to navigate.
    Once directed to the download page you need to click on "Download the manual" and follow the on screen instructions from there.
    Feel free to let me know if you need any further assistance.
    Kind regards
    Andrea
    Nov 22, 2010 | Computers & Internet
    Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
    ----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
    Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
    Computers & Internet Logo
    67 people viewed this question
    Alun Cox
    David Payne
    David Payne
