Question about Tomtom GPS
No GPS Signal for my Tom Tom Navigation 6 for my PDA on my AT&T Tilt
    Guru:
  • 1,894 Answers
Did u check with ur service providers??
i think they must helpu in this matter
not we
Posted on Jun 16, 2008
  • 1 more comment
  • dewan nafees ahmed Jun 16, 2008
    did u check with ur service providers??
    i think they must help u in this matter
    bcz there is no incoming signals
    do a hard reset and see.
    1. link
    that link is supposed to work
    there is some problem with the site.
    it wil be back after some tim i think sir.
    No valid signal means that the pairing is okay, just that the gps-unit isn't receiving good enough signals
    Go into the System Blootooth settings, pair the device and add an
    outgoing port on COM6 - make sure you UNCHECK the SECURE CONNECTION
    box...
    Then in TomTom, GPS config, select Other Bluetooth Device and then select COM6.
    (the same were provided to u from the link that was provided to u before)
    thank you
    dont forget to accept the solution if u go by it.
    have a good day
How do I change the time on my tom tom
The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
How to change clock settings To select the time format and to set the time, follow these steps:
Open the Main menu and tap Settings.
In the Settings menu, tap Set clock.
Select how the time should be displayed, then tap Next.
When you do not have a satellite signal, you are asked if you want to set the time manually.
Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | Tomtom GPS
Gps signal loss
Try the foll.: connect Tom Tom to computer using UBS lead, download update for your model from Tom Tom site-I'm no expert, but this worked for me.
Jun 24, 2009 | Tomtom GO 910 GPS Receiver
I do not always get a signel
This is a problem in many navigation system. Place yourself where you get signal. insert your route, write it down in a piece of paper this way you will have it handy for when you loose signal.
Tom Tom is my favorite system and the signal is very good in it.
Jul 07, 2008 | Garmin Nuvi 610 GPS Receiver
Tom tom cannot detect GPS signal
Install another navigation software (iGO8, Navigon, Destinator, OziExplorer, etc....) and check you problem again.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask
http://www.goodslowprice.com/en/unlock.htm
Apr 29, 2008 | GPS
Tom Tom 910 software
I don't think the Tomtom 910 has a SD card slot. Check the model # of your GPS again.
Apr 01, 2008 | Tomtom GO 910 GPS Receiver
Problem with gps not connecting.
I have Google maps for Mobile working on Mio P550 with GPS Program Port: COM9.
GPS Hardware Port to COM2, baud rate 4800.
http://blogs.msdn.com/windowsmobile/archive/2006/06/07/620387.aspx
Dec 24, 2007 | GPS
Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
E570 with GPS and Navi
Personally I have not GPS on my PDA but there is no reason that it should not work properly. The only thing is that you should pay attention on several things. Check by software producer if the software is compatible to your PDA. Please also be careful which ports use GPS hardware because your PDA has no USB port just serial port. With another words check all this important things before you buy anything.
Sep 11, 2005 | Toshiba e570
GPS Logo
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
