Question about Dryers
I have a maytag gas dryer. It runs great with the exception of HEAT. There is none. Where do I start to look and or troubleshoot this problem.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Gas Dryer runs and starts to heat, but cools off. It takes a long time to dry. Model #MDG2600BWW What could be wrong?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101./,,./
Jul 22, 2011 | Maytag MDG2600BWW Gas Dryer
Drum runs and does not heat. The dial does not move. It does not shut off. It is a Maytag gas dryer about 12 years old. Has worked great untill this problem.
heatman101
Apr 19, 2011 | Maytag Dryers
No heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes dont dry no heat Maytag gas dryer runs well but no heat clothes are damp
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
May 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer works in every way except does not heat
heatman101
Feb 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
Marvin
Marvin
