InFocus LP 600 Multimedia Projector Logo
Aldo Brincat Posted on Jun 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Self Shutdown of my Infocus LP600
Hi I have the same problem with the lp600, it shuts off after 10-15 minutes (totally off not stand-by) then it comes back on stand by mode, but if I try to switch it on it goes off again after 10 minutes!!!
I've cleaned the lamp filters with compressed air and with alcohol as per manual, I even cleaned the fans with compressed air but still with same problem.
lamp is still working fine. it's the unit which is turning off!!
pls help!!!
thanks
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Aug 03, 2009
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
991888
Points
5072
Power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
How do I reset the lamp timer on my lp600 projector
You can't. You'll just have to make note of it's current reading just like an odometer of a car when you replace a new bulb.
31helpful
4answers
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
2answers
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Infocus lp600
Clean your air filters. The unit will shut down if it overheats. Ensure that all the filters are cleaned and replaced regularly.
InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
