Question about Xerox DocuColor 3535 Copier
Hi there i have a Xerox Dc 250 and i have a fault code like this 061-328 ROS Connect failure can anybody help me please
  • Xerox Contributor
  • 185 Answers
The laser scanner is defective PN 062K20984
Posted on Feb 08, 2016
  • 2072 Answers
SOURCE: docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Posted on Mar 12, 2008
  • 3 Answers
SOURCE: xerox dc 12 copier system faulit 9-354
yellow toner not feeding
Posted on Aug 14, 2008
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Posted on Oct 27, 2008
  • 78 Answers
SOURCE: xerox dc-12 system fault - Error code 10-389
that could be your fuser/youll maybe have to reset an nwm
Posted on Dec 11, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
What is a ROS system Failure
ROS stands for Raster Optical Scanner which is the scanner head/lense. This will need some cleaning from time to time depending on how much it is used. consult the printer manual on how to clean it.
Aug 06, 2014 | Xerox Office Equipment & Supplies
Xerox phaser 6360 laser failure code 10
You may have to replace the laser unit. Code 10 is a warmup failure. You need to reseat the connector to the ROS Harness first. If the issue persists, replace the laser unit. Issue persists, check continuity between pins J15 and J151. If there is continuity, replace the Engine Control Board, if not, replace the ROS Harness
Feb 03, 2014 | Office Equipment & Supplies
Xerox dc 260 incident code 042-322
I have a Xerox DC-250 machine. Few days ago come a fault code 042-322, 1st I replace front door interlock switch & ready the machine. Next day morning when power on the same code come back, then I replace the MCU PWB & ready. Next day again same code, I replace the Xerographic Drawer & ready. Next day same code. So please help me how it possible to solve this problem for permanently?
Feb 05, 2011 | Office Equipment & Supplies
Xerox Docucolor 3535 fault code 006-372
That is a problem with the laser or ROS polygon mirror motor.
It most likley has failed.
Google a business called The Parts Drop, call and ask for Britt.
They can help you parts wise. Its not real difficult to replace.
Oct 24, 2010 | Xerox DocuColor 3535 Copier
Fault code 006-381 on a xerox workecentre 24
That is a ROS ( laser ) fault.Either the ROS unit or the MCU ( main processor board) have failed.
Honestly, its a tossup as to which is the problem.
Mar 30, 2010 | Xerox WorkCentre M-24 Color Copier
580 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
