Question about Desa International Televison & Video
I wanna buy a remote control for DESA Gas Heater NZ 118.
2 Suggested Answers
  • 30 Answers
SOURCE: I have a NY116 (DESA/Comfort Glow) heater w/
The remote control was made by Skytech. You should get the information off of the remote and the valve and contact them for parts.
email
support@skytechsystem.com
fax
888-672-8024
phone
888-672-8929
address
9230 Conservation Way
Fort Wayne, Indiana 46809
Posted on Mar 04, 2010
My infared heater no loner works by remote or manually pusings buttons. running constant
you may have a stuck bi metal t- stat try tappiig lightly on top by controller if you unplug prior to tapping onit it shound still come on when plugged in agian if its verry cold and comes on when pluged in then get a $4.00 timer and set at intervals tempory fix til you can locate a t-stat ,you may want to send in for service if you dont have skill set to repair it.
Feb 18, 2015 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a vermont castings radiance 2600 fireplace, the pilot light is lit but the on switch isn't turning the fireplace on
desa is out gone but maybe pro com have a controller with the same controls as the desa check #on the control and see cross ref in Google search they can be 80.00 and up but can b found
Dec 10, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Looking to find out if my gas fireplace unit has a "milli volt gas valve" to change it to a remote control unit. Model # CGG363OP Is this remote capable and if so can you sell me a remote for...
Marty, I would really like to help you, but the DESA/Comfort Glow Model Number you listed is incorrect. Please check & confirm it and get back to me.
To visually tell if your gas control valve is Millivolt or not. First, look at the pilot assembly. If it has a thermopile attached to the top of the pilot, it's millivolt controlled. If you are currently using a wall switch to turn the burner ON, it's millivolt controlled. If the control valve has 3-electrical terminals on the side of it, it's millivolt controlled.
As far as selling you a remote control kit is concerned, we at FixYa do not sell any products of any type. But, you can buy them from a hearth store in your area or online. I would recommend looking for a SkyTech Remote Control Kit, as they are one of, if not the best on the market. Plus, they come in a a host of models depending on what you want the remote control to do.
Hope this helps you and thanks for choosing FixYa.
Sep 08, 2011 | Desa International Heating & Cooling
Why do I have to press the remote control several times (between 6 and 12) to get the gas heater to turn on? And when the temperature reaches the set point and turns off heater, it will not go back on...
The first thing I would do is make sure that your batteries are in good shape and that connection in the remote and baterry ends are clean.
You can easily clean the ends on your batteries by rubbing them briskly on a piece of denim or other semi rough cloth and use a fine grade of sandpaper to clean connections inside the remote. Thank you
Jan 06, 2011 | Desa International GWN30T GLOWARM® Gas...
I have a NY116 (DESA/Comfort Glow) heater w/ remote control. The remote control doesn't appear to show the room temperature while in Progrom Mode... preventing the heater from turning on. It works fine in...
email
fax
888-672-8024
phone
888-672-8929
address
Jan 05, 2010 | Desa International HRC201-4 Remote Control
I have a gas log fireplace with lmfp33pr log unit. The remote wont work. They have new batteries. The manual swirch will work. What do you think the problem is?
did you put new batteries in both the remote and the remote sensor box . if so you will need a new remote you can buy for about 100 bucks it includes the remote and remote sensor, its not hard to install . any gas log supplier can assist you
Dec 03, 2009 | Desa International Unvented Gas Space...
My heater will not react to the remote control. I
The manufacture did change remotes for some of the remote controlled units. You may have the older remote/receiver and need to replace it with the new verison. You can find the manufacturer online at www.desatech.com and find parts distributors.
Oct 20, 2009 | Desa International GWP30T Heater
While the pilot remains on and the remote control seems to be working, I think there's a problem with the connector box in that I don't hear a beep and it doesn't ignite the fire. I changed batteries and...
The remotes for gas fireplaces are lousy and cheap...I would try going to the gas valve on the unit and take a small jumper wire.....jumper the connections the remote are hooked up to...if the unit comes on and runs normally trhats the problem....you can run 2 wires from those same terminals to a switch on a wall and operate it that way...more reliable
Oct 17, 2009 | Desa International Unvented Gas Space...
Operating instructions for heater & remote control
visit this web site..this should be very similar to your remote.. http://www.abergas.co.nz/anytime/pdf_files/anytime48b23cc130447p314.pdf
Apr 14, 2009 | Heating & Cooling
Televison & Video Logo
51 people viewed this question
Top Desa International Televison & Video Experts
Are you a Desa International Televison and Video Expert? Answer questions, earn points and help others
