Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero not cooling properly
I have a Sub-Zero with bottom freezer. Every year we have to call a repairman to come to the house because the fridge portion is not cooling. The freezer portion is making ice and working just fine. The repairman does fix it but we don't know what he is doing to fix it. At $600.00 a visit we really would like to get some suggestions on what to try ourselves, suggestions????
  • duece1932 Oct 21, 2008
    i have the same problem pls nn solution
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
found leak at evaporator, made a video how to replace it on Sub Zero Vacuum Condenser Light stayed on
Posted on Jun 27, 2015
    Problem Solver:
  • 8 Answers
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer. If the guy you have had in the past keeps coming back every year, the he is either recharging the unit without changing the evaporator or you have a leak somewhere else. Call a authorized Servicer.
Posted on Oct 13, 2008
    Habit-Forming:
  • 41 Answers
It's a definitely evaporator leak...Cheapest thing - your tech should recharge freon with some add on as a Stop Leaker or something. Any appliance parts supplier has it. Usually it's good enough and working long time, more than one year :)
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Posted on Jul 23, 2008
Most likely you need an evaporator and drier. Sub Zero warranties the parts for 12 years, labor to replace should be 300.00 plus depending on your area.
Posted on Jul 19, 2008
You have a leak and he is coming and putting a charge of freon in your system. This will usually last a year or more. Your problem is a leak . Very hard to find sometimes,
dartmanc
Posted on Jul 11, 2008
Why would a sub zero model 650f freezer freeze up ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Fridge not cooling properly
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 08, 2011 | Sub-Zero 650 / O Bottom Freezer...
Fridge does not stay cold but the freezer works
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Sub-Zero 650 / O Bottom Freezer...
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer does not work
Most model numbers are located in places like the photo shows below. It may be the thermostat itself causing the problem with freezer, yet I don't believe I have seen a refrigerator running without using the freezer to cool the refrigerator section. I guess anythings possible. Let me know, Thanks, Sea Breeze
Apr 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero not keeping cold. It will cycle on and cool properly, then after a while the temp goes up to near 50 and it takes too long to cycle on to cool down again.
Call a subzero repairman. My subzero had a leak in the refrigerant coolant tubing. Trust me, only a trained and equipped repairman has a prayer of fixing this.
Mar 16, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
743 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
