Question about Canon Office Equipment & Supplies
I can't get my scanner to work - Canon Office Equipment & Supplies
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
Driver suitable for CP-HR7X Slim Scanner to work in Windows 7
I can not find driver suitable for scanner CP-HR7X to work in Windows 7 too. I am from Russia.
May 27, 2009 | Genius ColorPage HR7X Slim Flatbed Scanner
Umax powerlook III scanner not working with latest mac system sof
Your OS is not compatible. Period. Either go back to what worked for you or get a new scanner that will work in new environment.
Jun 23, 2017 | Umax PowerLook III Prepress Flatbed...
Scanner dint work
I purchased Canon DR 9080C scanner two years back but the CapturePerfect 3 not received. So speed is slow. Can Canon Big help me to provide capture perfect 3 software. My email is prakashkhedekar@gmail.com
Jun 07, 2008 | Office Equipment & Supplies
Want umax scanner software
I want a software driver for Umax Astra 2000P Scanner Flatbed Scanner for Windows Xp Operating system.
Dec 29, 2007 | Umax Astra 2000P Scanner Flatbed Scanner
Scanner has stopped working
When I had the cable that came with the printer connected to the scanner, and the cable that came with the scanner connected to the printer, the scanner didn't work.
Changing the cables changed everything.
Oct 15, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Can't get Scanner to work
hello the scanner wount evevn do enything
im so angry
Mar 31, 2007 | Compaq S 200 Flatbed Scanner
19 people viewed this question
old marine
old marine
