Question about Acer Aspire 6920 Notebook PC
Hi i own a acer aspire 6935g and have just updated to window 7 prefessional the cinedash media console is very intermitent occasionally the pause play mute functions work but the volume key does not respond
  • 24 Answers
Try to install the new drivers for media console from here and see if this solves the problem...
Posted on May 03, 2011
Hi, in my Acer Aspire 8930G does not work more CineDash Media Console. is left as if it were canceled and I can not get it to work. Thanks for the help.
You will need to reinstall the software and drivers that control cine dash to restore functionality if that does not work a factory reinstall should restore functionality.
Drivers are available for download here http://us.acer.com/ac/en/US/content/drivers
Feb 28, 2011 | Computers & Internet
I have the acer 6935g notebook and had windows 7 installed and i can't get my virtual surround sound working can you give me any clues. thank
Windows 7 has over performed most softwares codes as computer customisation programs. Windows 7 computer requires newer programs softwares to acheive an improved experiece. Attempting to tweek windows 7 sound may create malfucntion. simply acquire a video or audio sound manipulator. for example, media softwares provide equalisers, bass blasters, voice enhnacers and finally acquiring a home theater system brings out the impression in media.
Jan 29, 2011 | Computers & Internet
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
I have aspire 6935G and my cinedash media console is no longer working..it just freeze...pls help..
hi there i have just had the same problem on my 6935g and i found the way to solve it is to take the bateery off for 30 secs and when you start it back on the problem should be solved it is not the answer to the problem as it may recure but it gets your cinedash working again the site i got this solution said that this is the solution that acer give out
Jan 15, 2010 | Acer Aspire 6920 Notebook PC
Unlock volume console
Hi, Try doing the following:
1. Turn of your laptop 2. Remove the battery and the power cable for about 15 seconds 3. Reinsert the battery and the power cable 4. Turn on your laptop.
Your Cinedash Console should be fully functional again
Good luck. Cheryl
May 28, 2009 | Acer Aspire 6920 Notebook PC
Cinedash touchpad
Try taking the battery out for 10 seconds, put it back in and boot as normal.
Worked for me on my Aspire 6920G! I think it must be a power-ratio problem.
Mar 29, 2009 | Acer Aspire One PC Notebook
Volume touchpad has frozen on mute
This happened to me.
Power down (shut down) and then remove battery for a few seconds.
This fixed my CineDash Media console.
Jan 17, 2009 | Computers & Internet
How to use the CineDashMediaConsole on a ACER Aspire 8920
Every now and then, the CineDash media console on the Aspire Gemstone Blue models freezes, turns off, refuses to work, leaves you in locked out of the car in the pouring rain… The causes are endless, but the solution is quite simple.
To reset the CineDash, remove the power cable AND the battery for more than ten seconds.
Tadaa!
Sep 18, 2008 | Computers & Internet
I have an acer aspire 6920 laptop.the cinedash media console isnt responding
Functions are activated by simply tapping
the function with your finger, while you can adjust volume by sliding your
finger around the volume meter.
CineDash reacts on commands with a little “lag”, if you use it carefully you can expect no problems, but for nonchalant usage CineDash will not react on every touch. You also have to make sure that it's turned on for it to work.
Jul 21, 2008 | Computers & Internet
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
Acer Aspire 6920 Notebook PC Logo
328 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
