Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP Laptop freezes
My HP laptop freezes up once its been loaded. It might work for a few minutes then freeze up. After that it won't start or it will freeze during the start-up process. The start-up manager doesn't seem to help.
  • 1 more comment
  • Anonymous Apr 20, 2009
    I have almost the same problem (and I'm pretty sure the issue isn't overheating). My computer freezes after about 5 minutes and it won't start up agian unless I forcefully shut it down. I'm pretty sure it's not a virus because I have anti-viral software and I manually went through the programs and erased most of them (in safe mode the computer works fine). Also, setting the computer back to a previous point, when the problem didn't exist doesn't help. Erasing all the temporary files doesn't either. Also, when I tried pressing F2 when turning on the computer. It gives me two options: memory check and hard-drive check. The memory check determines there are no problems, but the hard-drive check fails...as in the computer refuses to do a hard-drive check. I don't know what to do to stop my computer from freezing. Please help!
    I have a similar problem. My computer freezes about 5 minutes after I turn it on and the only thing I can do is forcefully shut it down by holding the power button for 10 seconds. After I turn it back on agian it works for another 5 minutes or so and freezes up agian.
    What doesn't work: 1.setting the computer back to a previous point, when the problem didn't exist
    2. erasing all temporary files
    3. disc clean-up
    4. F2 (memory check is ok, but the computer refuses to execute a hard-drive check).
    What I know: 1. works in safe mode
    2. problem is not overheating
    3. problem is not a virus
    I hava an hp pavilion dv 2910us Entertainsment Notebook PC
    What should I do to fix the problem? Please help!!!!
  • Lori Apr 20, 2009
    I have an hp pavilion dv2910us Entertainment Notebook PC and have a similar problem. The computer freezes after about 5 minutes and I have to uses the power button to shut it off, but when I turn it back on again I have the same problem.
    What doen't work
    1. setting computer back to a previous point when problem didn't exist
    2. disc clean-up
    3. erasing all temporary files
    4. F2 (the memory check works, but the computer refuses to execute a hard drive check...it says the check failed)
    What I know
    2. not overheating problem
    3. not a virus problem
    4. If I try to log-in as a guest as opposed to regularly, the computer freezes right away (as opposed to after 5 min).
    What should I do? Please help!!!!
  • 106 Answers
It seems like you have some over heating issues. Compressed air can should do the job by the vents. If you're able to pull the cpu fan and heat sink assembly, then do so and clean them out. a tube of thermal grease will definitely help. you can apply it on to the CPU but make sure you clean out that no good factory grease before applying the new one.
best of luck
Posted on Jun 16, 2008
Sony vaio nb laptop touch screen freeze
Hello Adnan eickov
Pls go to start menu and select screen calibration option. and re calibrated.
Mar 05, 2014 | Computers & Internet
My touchpad on my hp pavilion dv6-1245dx keepss freezing
if ur connecting ur touch pad with a cable to ur laptop check for the cable wire compactibility
Mar 08, 2012 | HP Pavilion dv6000z Notebook
On June 4th, I got my new HP Compaq Presario CQ65-115DX. It worked great until only just a week ago. Suddenly, it began freezing. Thinking I had a virus, I ran multiple scans from several different...
It sounds like a memory problem. I would get a free memory diagnostic utility off the internet, load it on a flash drive and see what it tells you. You may even have such a utility pre loaded on the noteobook. Check during startup what functions are avaialble such a "diagnostics" on the bottom of the screen during startup (before Windows loads). If it is still within an exchange period then I would exchange it for another one. I used to sell notebooks and unfortunately Compaq's were the most often DOA and returned notebooks that we sold, even more so then the lowest end eMachines notebooks. If you can get another make and model I would do so now. IMO HP has gone downhill considerably since the notoris HP/Dell/Nvidia fiasco of a few years ago.
Jul 11, 2011 | Compaq Presario CQ56-115DX Laptop
Pls,i have a nc6000 Hp laptop of 40GB Hard disk, 1500MHz processor and a 256MB RAM which i added 512MB RAM to upgrade to 768MB RAM. It started to freeze/hang and prompting the mouse cursor to...
from the off position, turn on, continuously hit the F8 key to force the startup menu, select last known good configuration and reboot. If this does not work, do the F8 thing again, and select safe mode. If you cannot reboot, you will have to do a clean reinstal using your factory recovery CD. If you can get into safe mode, immediately start saving your files to whatever media device you can.
go to start/run and type cmd and hit enter - type in chkntfs /c e and hit enter, reboot. This will start and system checking procedure on bootup. Again, if this does not fix things you will have to boot from your recovery CD.
Jun 16, 2011 | HP Computers & Internet
I have an HP laptop and my built-in webcam freezes after just a few minutes. The ones I view seldom do. Any ideas?
hi, do disk clean up and if possible upgrade the RAM of your system so that it can hold load of graphics and streaming that's just it
Jun 20, 2010 | HP Pavilion dv9000z Notebook
Hi, I have an HP pavilion tx 1000, it does not boot, it starts off but then freezes in a few seconds.
TRY TO USE ANOTHER RAM TO TESTING.. AND ALSO THE HDD CHANGE.. FOR TESTING FIRST IF WHERE THE EXACT CAUSE OF NOT BOOTNG ANG FREEZING... OR THE DVD ROOM REMOVE IT THEN START THE LAPTOP
Jun 25, 2009 | HP Pavilion TX1000Z 12.1" Touch Screen...
WINDOW FREEZES WHEN OPENED MESSAGE SAYS ALPS POINTER PROBLEM
my compaq laptop freezes up when not used for a few minutes and then data is lost and I have to reboot it!
Jan 04, 2009 | HP Pavilion dv5170us Notebook
Laptop Freez up only a few minutes after I turn it on.
You possibly have to many programs starting up when you turn on computer,try going into msconfig and turning off things that you don't need to start up.
Apr 26, 2007 | HP Compaq Business NX9110 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
234 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
