Question about RTO Lifestyler Expanse 8.0 Treadmill Walking Belt
What is the weight limit on life styler expanse 550 treadmill
    Habit-Forming:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 36 Answers
250lb
Posted on Nov 08, 2010
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Jan 27, 2016 | Epic View 550 Treadmill
E2 error lift error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have posted this question in the Stair Climber section, but the error you are listing is a treadmill error code. The following information should help.
Probable Cause A) Incline control error.
B) Insufficient power source.
C) User exceeds weight limit.
D) Unit will not lift.
E) Unit thinks it is always at 0% incline and only lifts up.
F) 3 amp circuit breaker has tripped.
G) CPU board has stuck relay.
H) Lift motor is faulty.
Corrective Action A) Access the incline manual mode in diagnostics by pressing 9, 1, 9, ENTER and then pressing HILL program key. Incline the unit with two people on the unit. B) Ensure treadmill is connected to a dedicated 120V, 20 Amp circuit.
C) Advise user of unit's weight limit of 300lbs (137kg).
D) Perform the lift test procedure by pressing 9, 1, 9, ENTER and then pressing HILL program key.
E) Inspect the home switch for smooth operation and inspect the wiring of the home switch for damage or poor connections. Inspect the lift motor cable connections and for the presence of the suppressor board (should only be 1).
F) Test the circuit breakers and replace if necessary.
G) Replace the CPU board.
H) Replace the lift motor.
LifeFitness 9500 Treadmill Lift Control Error
Jul 31, 2013 | Life Fitness Exercise & Fitness
Treamill 9500hr is reading weight in pounds and not kg
Please go to the Menu, and go to the section go caractheristic and change the Lbs to Kgs.
God bless you
Jan 09, 2013 | Life Fitness 9500HR Next Generation...
Is there a weight limit on the Pro-Form 760 EKG treadmill? While I am walking the belt skips and I feel like I am going to fall.
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Aug 24, 2011 | Proform 760 CrossTrainer Treadmill
What is the weight limit on a treadmill
hi good day..When you run on a treadmill the impact is 2 1/2 times your body weight. The impact from walking is considerably less. Therefore individuals who weigh in over 200 lbs need to consider a treadmill that can withstand the additional impact. Most treadmill manufacturers overstate their weight limit by as much as 50-75 lbs.
Treadmills for Users Over 250 Pounds: If you are in the 250 lbs range you better find a model that claims to at least handle a 300 lbs user. Look for models that have a deck that is around and 1-inch thick. A ½-inch deck may break from users that are hefty..
Apr 19, 2011 | Health & Beauty
What is the heaviest weight someone can weigh to use a proform crosswalk 495cw model #831.299420
Most ICON products boast a 300lb weight limit. The actual weight is 175lbs. The manufacturer does not care if 300lbs is too heavy. It only has 1 year of warranty
Apr 09, 2011 | Proform 495cw Treadmill Walking Belt
Is there a weight restriction ?
It is not a restriction. It is a recommended limit of 300 lbs. See ProForm 695 LT Treadmill
If you weigh more than the limit, the machine will feel, and be, unstable. You could also harm the motor over time.
Dec 28, 2010 | Proform 695 LT Treadmill
What is the weight limit for the reebok rt 1000 treadmill
The weight limit for the Reebok RT1000 treadmill (Model #RELT1600.1) is 250lbs.
Dec 17, 2010 | Reebok Rt1000 Treadmill Walking Belt
Just got a used Life Fitness 9100 treadmill. When I turn it on and press sstart the display says enter weight. Before I can enter my weight and press start it resets itself back to the enter weight...
this problem is due to a false in the terminals that connect with the microswitch, you must remove the screen and back-side only remove the screws and tighten the terminal could also apply contact cleaner
Aug 07, 2010 | Life Fitness 9100 Next Generation...
How do I lubricate lifestyler treadmill? While it is running or not and wear to I put the lubricate. I was give a Lifestyler expanse 550 treadmill and have no book with it
Turn off the unit then lift belt and apply the lubricant on the middle of the running deck , then turn on unit start it at 1.0 mph start walking on it for about 5 minutes.
May 27, 2010 | Exercise & Fitness
RTO Lifestyler Expanse 8.0 Treadmill Walking Belt Logo
385 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
