Question about Garmin GPS
Garmin GPS map 182: seems to work fine, but does not show navigational aids. Boat is tracked, and route is marked, plus previous routes shown. However, channel markers are not showing up. Any ideas?
  • w52381 Jun 21, 2008
    We tried that already. Navigational aides, such as channel markers, do not show up.
    Scholar:
  • 174 Answers
Which channel markers? There is a settings menu for map detail, put that on highest (press menu once or twice to get to the setup menu)
Posted on Jun 16, 2008
Only shows us routes not canada
I fell foul of that the other way. I have Canada maps and lent it to a friend who was going to California.
You need a map that covers Canada and it is an extra cost. The USA is in two zones, or one map does both zones.
You need to buy the Canada maps and then put it on an SD card. The map costs $84
https://buy.garmin.com/en-CA/CA/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt-canada-only/prod8750.html
City Navigator North America NT Canada Only Garmin
Feb 20, 2016 | Garmin Nuvi 2360Lmt - Gps Receiver
Unit shows that No detail maps found that support routing.
Make sure you have your Map selected in your settings..... go to Tools.... Settings.... Map.....on bottom of screen press Map Info.
Is there a check mark in City Navigator North American NT..........if not you must have one in there to chose that map or whatever map you are looking for
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
While traveling to Nova Scotia last week, my Garmin Street Pilot c530 was telling that i was on an unpaved road, but i was on route 2 in New brunswick Canada
Don't believe everything you see on a GPS. Garmin does not update their maps as they should; I found this even after I purchased their map update. I drove 48 states in a big rig, over many new roads not found or shown on the Garmin maps. My streetpilot usually went into a hiccup mode, recalculating -- recalculating -- recalculating. All the while, it tried to get me to detour on whatever spurious local roads happened to show up along the way.
Aug 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Help I my nuvi navi says it doesnt have maps???? SOS
garmin are preloaded with maps for routing, never the less, you need to backup with software from www expertgps.com/gps-receivers/garmin-nuvi350asp OR drivehp.com/backup. your set may work after doing that. thanks
Mar 19, 2009 | Garmin Nuvi 350 Car GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
My garmin
it may be trying to get you back on track or if when turning it on it trys to take you a previously sort location you may have set this as your home. make sure your actual home address is stored as your home address on the gps unit.
Jan 10, 2008 | Tomtom GO 910 GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Route problem
If you don't have "Detailed Maps" for the area you are travelling in, it will not have adequate map detail to create routes that are not on major highways.
To remedy this, you will need to use another of GARMIN's products... I believe it's called Mapsource City Navigator, and will have to be purchased for the area you are concerned with. This PC software will then allow you to load additional Map Data onto an SD card, which will slip into the slot on the left side of the unit.
You can find out about it at their website www.garmin.com then look in Maps
Oct 01, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
99 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
