Question about HP Office Equipment & Supplies
Have a problem with printer via wireless - HP Office Equipment & Supplies
    Genius:
  • HP Expert
  • 1,325 Answers
Hello
what is printer model ?
what OS are you using ?
have you installed the drivers correctly ?
Posted on Nov 08, 2010
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
Netgear d6300 won't find a wireless canon ip7250
If the printer is connected via wireless it may not be set up correctly, as a network printer.
Connect it up via a USB cable to make sure it works, then change it to Wireless configuration and re-install it as a network not a USB printer.
Nov 26, 2013 | NetGear Computers & Internet
HP 6400 wireless printer will not work with netgear wndr3400v3 router
see manual
http://www.hp.com/ctg/Manual/c01325559.pdf
Sep 13, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a very old HP LC3 netserver. It was in my office, and I have moved it to my home. I would like it to communicate with my printer in order to print out documents. Can it be connected directly to my...
Add the printer to the wireless router as another node via DHCP. Then add the printer by the IP address. Your server does not have wireless so it will need to be connected to the router via network cable.
Or, you attach the printer directly to the server via parallel port (RS-232) cable. Or upgrade the server with an USB port, and connect it that way. gl
Mar 23, 2013 | HP NetServer LC3
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
Issue: I have a Canon Pixma iP6220D inkjet printer and it will not connect to my computer wirelessly (my computer does not support Bluetooth). Query 1: What type of wireless technology does the printer...
1) This particular printer is available in versions that connect via Bluetooth or via Infra Red. There does not appear to be a Wifi version. 2) To get it to work via WiFi, you'll need PC with Wifi and 3) a Wifi print server like this
Amazon com TP LINK TL WPS510U 150Mbps Wireless Print Server USB 2 0...
Dec 30, 2017 | Canon PIXMA iP6220D InkJet Photo Printer
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Hey, i recently got a Mac and tried to connect my Z1420 wireless Lexmark printer to it. The wireless did not work, but when i connected it via USB the printer worked. I settled for this but recently the...
You stated you have a mac. Is your Mac a laptop that provides wireless? Or are you on a Mac desk top connected to a router that has wireless included with it.. If you have either than you need to go into your network and sharing to set-up the wireless printer. This will give you access to your router via desktop or your wireless settings via laptop,
Once there if you are already using wireless settings you are going to have to allow your printer in through your wep or wap encryption settings. This was set up when you first started using your wireless to keep out intruders.
Mar 08, 2010 | Lexmark Z1420 InkJet Photo Printer
Connecting from a Mac via wireless print server
Dissconnect USB cable add ethenet cable find printer on Mac set to default should work fine then worry about the wireless side inkypete
Apr 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
15 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
