Question about TruTech PVS31170S1W 17 in. LCD Television
TV will not come on
I had a power surge and my tv will come on I think that it could be the fuse could you tell me the on I would look at all the location to fix my tv is to far away a live in north Minneapolis, MN
  • 1 more comment
  • Anonymous Aug 01, 2008
    TV WAS WORKING OKAY WHEN SUDDENLY A LOUD ALARM-TYPE BUZZING CAME FROM IT. IT DID NOT RESPOND TO REMOTE OR ON/OFF SWITCH, SO I UNPLUGGED IT. WHEN I PLUGGED THE TV BACK IN 12 HOURS LATER, THE BLUE LIGHT CAME ON FOR THE DVD PLAYER, BUT THERE WAS NOTHING BUT A BLACK SCREEN. NO PICTURE. NO SOUND.
    READING THE PRODUCT REVIEWS SURE DOESN'T GIVE ME A WARM FUZZY FEELING.
  • Anonymous Aug 17, 2008
    I HAVE SOUND BUT NO PICTURE AND TV IS LESS THAN A YEAR OLD
  • Anonymous Sep 15, 2008
    I bought the trutech tv and a little bit after a month you can only hear the sound but not the image.
  • 3 Answers
I called the manufacturer and they said I could send it back to be repaired or replaced. It costs $45 if its after 120 days on the receipt (they extended it another 30 days) or no cost if within the 90 (120) day period. He said there is a 1 yr warrenty on the fixed or replaced on as well. Here's the phone number 1-888-252-6252! I hope this helps someone!
(I got this number after calling target's manufacturer hotline that they give u in the store when they tell you they wont take it back)
Posted on Aug 19, 2008
After u fix this please buy hd700 monster cable power strip if it dies pluged in to this monster will pay for it 79 bucks u must use thes eon flat screen never plug them directy in wall fuse in ther u wont be able to fix its mor eliek resister proably blew in it
Posted on Jun 16, 2008
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: TV will not come on
Hope it not serious. Do a hard reset and try again. You can do the reset by unplugging the power cord for a couple of hours; then power it up again.
If the reset does not solve the problem then it is serious! The blinking light means the set has gone into protection mode. This is when the system has detected a short or something that is drawing excessive current. The protection system shuts down the main power supply in order to prevent further damage to the set.
In the majority of cases the blinking light means the main power supply has gone bad, but it could also mean other things as well.
Repair is usually on the expensive side, unfortunately. You will need to find someone who can go inside the set, take some measurements in the power supply and track down the ailing part of the set.
Hope that helps........
Posted on Jul 02, 2008
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
No power indication at my tv
try this first
How to Reset TV After Power Surge eHow
sometimes there is more than one fuse on power supply
Jul 24, 2015 | Televison & Video
50"sony led no picture or sound after power surge
I think you just have to switch on the TV again. the switch number 5 on the right side of the TV should be pressed once.
Jul 27, 2014 | Sony Televison & Video
Wont turn on
whille tv running after 5minutes
shotingdown
Nov 26, 2013 | Akai CF2791 27" TV
Because of a power surge, i think i fried my tv, are there any safety procautions inside that might protect the tv, such as fuses, or would it just ruin the tv?
there are fuses and MOV's to protect for surges.
mov is metal oxide varistor, a resistor that shorts out when the voltage rating is exceeded causing the fuse to bluw.
always right after the fuse on the circuit board on the powersupply board
Mar 30, 2011 | Sony KDL32L5000 32 in. LCD HDTV
We had bad weather lights went out ..had tv plugged into a power surge plug ...now that i have power back tv wont come on
Some will say a surge protector will save electronics. I can tell you they may not help at all. A power surge is extremely fast and can over ride the surge protector. If you think you can repair this TV, I would certainly remove the back cover and inspect. Occasionally the only problem for repair is to replace the main fuse. Remember, this happens rarely. Most cases after a surge the TV will need to be inspected by a TV tech. Almost anything, in a power surge will damage the TV. There is no certain area that will not be damaged, expect it any where. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 47PFL3704D 47 in. LCD TV
T.V blew Out after power surge
Once you have the back off the TV...look to see if there is a board mount fuse that can be replaced
Apr 07, 2009 | Televison & Video
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Tv will not power up when turned on after a power surge occurred.
Prayfully the fuse inside the tv took a little shock and broke ...if not that would leave the transformer or the board took a surge also but this would also depend on a little more details...
was the power surge damaged?
was tv plug damaged?
does the power surge still work (if it wasn't damage)
and not all power surges are power surges unless it specified of purchase most are like power surges but are only close to and a extended extention cord updated..
if the power surge is damaged or even still works then go have the fuse check and any further damage will also show up on the board it will have a burned part...
Nov 11, 2008 | Televison & Video
Power surge
Change the horizontal output transistor if you know where it is. keever
Jan 02, 2008 | RCA 27V520T 27" TV
TruTech PVS31170S1W 17 in. LCD Television Logo
80 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
