Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My ice maker quit makinf ice. Have not made ice fir three days.
  • 4,070 Answers
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Posted on Nov 08, 2010
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
Model 106.57036601 Ice maker quit working couple days ago had water off in whole house, had to repair a water pipe in the restroom.
There are a couple or three ways to test your ice maker and dual water control valve to identify the location of the problem. By looking at what the ice maker did on its last cycle or the lack of a cycle will help a lot. If ice maker has old cubes then the ice maker has not cycled and that tells me that the ice maker has been turned off or it has become defective. Another test is to pour tap water into the empty slots if there was not old cubes there. Allow the water to freeze and if the ice maker cycles and dumps the cubes into the ice container that would indicate a defective dual water valve=> 4389177 Water Valve Kit- Double Outlet The first three numbers of your model tells me it was made by Whirlpool and that tells me that removal of the front cover of ice maker you have test points. If me knowing what I know of ice makers I would be prepared to change both ice maker core=> 2198597 Ice maker - Replacement
Below is a short You-Tube ice maker help tutorial by the Appliance Assistant that can be very helpful. Should you have questions please ask, Thanks, Sea Breeze
Jun 10, 2011 | Kenmore 56733 Side by Side Refrigerator
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice makers generally only last about three to five years depending on the use and water quality in your area, a new ice maker is about $100 most of them take a part number D7824706Q check with your local appliance parts store.
Jul 14, 2009 | Refrigerators
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Ice maker won't work
There are usually two solenoids one for the water and one for the ice, you can trouble shot by switching the wires on the solenoids and see if you can still dispense water. If you can then the icemaker inside is where you problem is and it is easy to replace usually one elctrical connection and thwo maybe three screws and can be purchased online...
Jan 20, 2009 | Kenmore 55609 / 55602 / 55604 / 55606 Side...
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water works fine - No Ice
Does it sound like everything is running, only the machine isnt makinf ice? If so, there is a small triangular housing with a hose connected to the small motor on the left under the front panel. shut off the machine and remove the 3 screws on the triangular housing. inside there is a spring and a round rubber disk. take these items out and clean them. its amazing a tiny amount of debris will cause this to not work. install the reverse as you removed thewm, turn the power on.
Jun 03, 2007 | Hoshizaki Cubelet Ice MakerDispenser Water...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
