Question about Carrier Heating & Cooling
Apu starts fine but no fan no heat and no air conditioning and no 120 volt.
    New Friend:
    Problem Solver:
  • 6 Answers
Hi there, Would this be a preheat / comfort pro APU? If so I would start with removing the top cover on the APU. There will be a fuse holder with a 20 amp fuse on the back wall on the left side of the APU above the APU controller. Check and see if the fuse is blown. If it's not then the CCU board under the bunk/ bed isn't seeing power. Either 12v harness or the communication harness both from the APU controller to the CCU board are rubbed on the frame, or the CCU board isn't transferring power properly. The CCU board is under the bunk. There are 4 3/4 bolt's that hold the lid on. Start the APU and look at the board you should have green light's light up. these light's are called input light's. Then chose a function on the driver control panel as in heat, a/c, low or high fan and see if they come on. If the driver control pane are showing the function on look down at the CCU board and see if there are orange light's on. these light's would be your output light's. There's a lot of cause's for this problem if you need further help feel free to ask. Thank's
Posted on Dec 01, 2013
  • Cody Aery
    Cody Aery Feb 18, 2016
    Orange lights did not come on. What would be the next step in troubleshooting?
I have same problem, on CCU I have only input lights on , why my output lights off(hvac not turning on) ?
Posted on Jun 19, 2014
  • 81 Answers
Out sideboard faulty or indoor board. whats an apu?
Posted on Nov 09, 2010
My carrier apu starts fine, on low ac it will stay running but the display goes to check apu engine. On high ac it will run for a few minutes and kill the engine. Could it just be a fuel filter issue?
Hi, I do not think a fuel filter will fix this problem. You may need to take this unit in for service. If the fuel filter was to blame. The engine would die at both fan speeds. More than likely The APU controller has identified a fault and shut the system down. I feel that the A/C high function is directly related to the engine shut down. Driving down the road (vibrations) can knock things loose, wiring can get damaged or its just wear and tear. You can remove the covers and visually inspect the connections. Look and see if anything looks loose, broken or over heated. You can also inspect the HVAV blower motor and speed resister. Specifically the wiring at the connector. Over heated wiring can melt and cause a short that can affect system operations. Please start here and write back. Good Luck.
Sep 30, 2018 | AC Cars & Trucks
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
No heat unit is blowing cold
thermostat, heat sequencer, heat elements, fusible link no 240 volts. fan works on 120 volts.
Jan 24, 2014 | Ruud UBHC Air Conditioner
Ruud troubleshooting
do you have the lower door in place tight ?? because there is a door button switch. so if its not pushed in all the way you would have no power at furnace. also make sure nobody turned off the on off service switch usually above furnace or sometimes one at top of stairs and one down by the furnace .if those suggestions don't work you might want to turn each breaker off then back on incase one is tripped. if that don't work check for 120 volt at your fan timer board also it may have a automotive style fuse on the board which if blown it wont do anything. if there is 120 volt at board and the 24 volt circuit fuse is good its probably the fan timer board.
Jan 17, 2014 | Water Heaters
Heat coils in central air conditioning unit look fine under examination, checked with an ohmmeter both coils showed continuity. Power at both coils indicated 110 volts. Unit fan runs fine but there is no...
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
Jan 17, 2009 | Heating & Cooling
MY BLOWER WAS REPLACED IN THE SUMMER BUT IT NEVER TURNED OFF UNLESS WE SHUT IT OFF AT THE SWITCH. NOW I SWITCHED THE TSTAT TO HEAT AND THE INDUCER FAN TURNS ON WITH THE BLOWER BUT NOTHING EKSE TURNS ON. NO...
be sure the fan setting on the stat is set for auto, not on. in this mode the fan should only run when there is a call for cool or heat.if the fan continues to run check at the control board to see if you are getting 24 volts low voltage between green and common. if you are then the stat is bad. if youaren't then your electric control board is possibly bad. a lot of gas furnaces fall into a failsafe mode when a sensor or function fails and the blowers stay on 24 7. you may well have several problems from what you are saying. if you turn everthing off and start a new cycle for heat the first thing that should fire up is the induced draft motor , then the ignotor, then the gas valve. you can check each item with a meter , generally 120 volts to the induced draft motor, then 120 volts to the ignitior, the 24 volts to the gas valve. then ignition and 120 volts to the motor. most furnaces have a heat terminal and a cool terminal on the board. common to heat should get 120 volts on a call for heat after the sequence of operationb has taken place. 120 volts should be sent to cool terminal on a call for cool. a continueous blower is a sign of a failed safety. perhaps the motor failed and the safety opened and the motor was replaced but the safety never reset?. look at all the little micro temp sensors around the burner. they are like little breakers and need to be pushed in to reset . usually like a little stem that pops out from a metal or plastic dic. some are size of a quarter, some the size of a dime.
Oct 29, 2008 | Heating & Cooling
Heating & Cooling Logo
2,118 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
