Question about Western Digital USB 2.0 External Enclosure + Hard Drive WD3200JB 320GB ATA133 7200RPM 8MB (NEWITEM31869181) Drive Case
I need an external hard drive enclosure for my WD600VE hard drive. What should I look for? How do I choose?
    Top Expert:
  • Western Digital Master
  • 14,161 Answers
Posted on May 24, 2016
3 Suggested Answers
  • 1684 Answers
SOURCE: What kind of case enclosure (3.5) should I buy?
Check out the review on the hard drive case we use in our shop at www.ccl-la.com We have been using these drive cases for a while and have had no complaints, and it works for both IDE and SATA.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 08, 2009
lock123
  • 6831 Answers
SOURCE: Unable to use Sabrent External HArd Drive Enclosure
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Does not recognize the hard drive
First unplug USB, You can try restarting your pc, power on the external hard drive, then plug it into the PC, windows should see it, if not try below.
If you computer or laptop has USB 2.0 or 3.0 ports you do not need a driver, it in windows.
Try this- Right click on my computer
Choose MANAGE
Then find DISK MANAGEMENT
You should see your ext hard drive under the list.
Right click on it, and choose CHANGE DRIVE LETTER
Choose anything, but I recommand something higher than F.
Apr 15, 2013 | Imicro IM35ST500SI 3.5 inch...
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Needa external harddrive for the acer aspire one series mini labtop
If your computer has an external USB port, then any external storage device (memory-stick or external disk-drive) will be compatible.
Mar 28, 2011 | Computers & Internet
Can i upgrade a ide and sata drive on my compaq presario sr2010nx pc?
yes you can. i suggest using a program called acronius true image. add the new hard drive. be sure to turn on the sata or ide option in the setup bios. then use the true image software to clone your operating systems to your new hard drive. your source drive will be the original drive, and the destination drive will be your new drive. once the operation is complete , youll need to enter setup again and suggest that the new drive be your first boot device. just follow the on screen directions to complete the new setup. NOW... you can keep your old drive for a backup drive , or... you can format that drive and use it for a secondary storage drive. the hard drive can be accessed by my computer then open the drive and simply drag and drop or choose the drive from a save file drop down selection location popup window. this will allow you to save important files that can be accessed at anytime if your system main drive were to ever fail. another option you have is to place your old hard drive in a external hard drive enclosure that can be purchased via ebay and will allow you a large storage device that is mobile and hold mass data unlike a flash drive. this can be a very valuable tool and wont cost more than 20.00 here is a link for an ide hard drive enclosure with free shipping. if you need a sata enclosure, change the search results to (3.5 sata hard drive enclosure) the choose buy it now and choose PRICE+shippind:LOWEST FIRST. hope this was helpfull.
http://cgi.ebay.com/3-5-External-Hard-Drive-Enclosure-USB-2-0-IDE-BLACK-AC-/320627700742?pt=PCC_Drives_Storage_Internal&hash=item4aa6e67406
Jan 17, 2011 | HP Compaq Presario SR2010NX PC Desktop
No proble i want connect hdd to usb port by cable interface
Most of the time, you will need a hard drive enclosure that will allow the IDE or SATA connection to USB connection. These enclosures will allow you to insert the drive in the housing which will offer the USB connection cable from the enclosure. Check Ebay or other vendors for external hard drive enclosures.
Below is a link to an ebay listing for External Hard Drive enclosures.
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1311&_nkw=external+hard+drive+enclosure&_sacat=See-All-Categories
Dec 23, 2010 | Hitachi (IC25N060ATMR04-0)...
External hard drive problem
It sounds like you may a defective external enclosure. what I'd first recommend doing is trying it on a different computer. If you get the same problem, try removing the hard drive from its enclosure and putting it into your PC/Mac/Whatever. if it registers in the BIOS, then the hard drive is fine, you'll just need a new enclosure. you can get them for fairly cheap at Newegg.com, but remember, its usually cheaper for a reason...
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=92&name=External-Enclosures
that will take you to the external encosures
Jun 18, 2010 | Western Digital 320GB MyBook External USB...
Stopped responding
Hi whata
Plug the external hard disk into another computer's USB 2.0 port. If the problem follows the device, then there is a failure either of the external hard disk enclosure or of the hard disk (inside the enclosure).
If yours is one that you built yourself, you can remove the hard drive from inside the enclosure and plug it directly into a desktop computer (or another external hard disk enclosure) to see if the problem follows. (If you need help w/ this, just let us know.)
If yours is a pre-built external hard disk (you bought it w/ the hard drive already built-in) then you'll (if you're inclined to do so) need to open the enclosure to get at the hard disk inside. This can be difficult. You may, depending upon the enclosure, need to damage the enclosure to get it opened up.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Computers & Internet Logo
266 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
