Question about HP Officejet J3680 Multifunction Printer InkJet
How do you get the J3680 to switch from fax mode to print mode?
  • HP Master
  • 7,733 Answers
In the system tray you have those options just press any of the button you want to.
Posted on Nov 09, 2010
How do I receive a Fax on a J3680
1- Connect the telephone cable shipped with the printer to LINE-1 of printer and telephone wall jack
2- On printer press Setup(wrench) button >>>> select Advanced Fax Setup >>>> select ECM (error correction mode) >>>> select "off" >>>> press OK
3- On printer press Setup(wrench) button >>>> select Advanced Fax Setup >>>> select Fax Speed >>>> select "slow" >>>> press OK
4- On printer press Setup(wrench) button >>>> select Basic Fax Setup >>>> select Rings to Answer >>>> select 6 >>>> press OK
5- Make sure auto-answer is turned on.
6- Request a friend to send you a fax
Wish for all success..
Dec 22, 2010 | HP Officejet J3680 Multifunction Printer...
We have a new hp officejet J3680 all in one printer. we can not get it to scan but it does fax and print. Help!!!
Please click here to download and install the full-feature software driver and then try scanning. Make sure that the USB cable is disconnected before installing.
Regards
Riztech
Sep 06, 2010 | HP J3680 Officejet All In One Printer
HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Jul 21, 2010 | HP J3680 Officejet All In One Printer
When i recive fax or when i print it just it prints empty page
If the fax is acting like it is printing (print head moving back and fourth) then it sounds like the ink cartridge is clogged. Remove the cartridge and clean with cotton swab and rubbing alcohol. If this helps a little or not at all replace the ink cartridge. If it still prints blank, the print head could be the problem (this is where the ink cartridge goes). At this point it would be cheaper to replace the fax.
May 14, 2010 | HP J3680 Officejet All In One Printer
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Apr 30, 2010 | HP J3680 Officejet All In One Printer
I wanto to sentd through the fax a pdf document
Your printer has to be on the phone line.
The printer drivers must be installed.
Open the document with your reader.
Select print.
Choose the FAX printer, not the regular printer.
Click print. (you will be asked for phone #, etc)
If the drivers are loaded correctly, that's all there is to it.
Apr 21, 2010 | HP J3680 Officejet All In One Printer
Hp j3680 fax/printer is loud
Press on Setup--> then scroll down and select Basic Fax Setup--> then scroll down and select Ring and Beep Volume and reduce it.
Apr 08, 2009 | HP J3680 Officejet All In One Printer
Where is the fax set up to tell the J3680 not to answer automatic
i fixed the fax set up (from the machine itself) to answer a fax on the triple distinctive ring. we don't have that on our phone service, but this way, i can change it back to a single ring if i'm expecting a fax.
Feb 19, 2009 | HP J3680 Officejet All In One Printer
HP Officejet J3680 Multifunction Printer InkJet Logo
75 people viewed this question
Seeker5211
Seeker5211
