Disc player won't play certain discs
The unit will play cr's but not dvd's...
    Genius:
  • 1,036 Answers
Hi there!
Does it say it plays DVD's? If not it's not meant to.
If it should,there is a problem. Try a lense clener disc first, If this does not resolve it, then either the optics or reader components are at fault.
Posted on Jun 20, 2008
Won`t play dvd`s.try a cleaning disc no luck!possible dvd diode gone?any help please.Nigel...
Hi Nigel,
There are three reasons for discs not playing.
First, if the set has been lying for some time, the loading belt becomes lose and the loading is not complete. The result is no disc play.
Second, there is dust on the lense. Again the result is no disc play.
Third, the lense unit has gone bad or weak. Here also the result is no disc play.
Jan 24, 2016 | Televison & Video
Optoma dvd 10 troubleshoot dvd rw
sometimes it is just the brand of disc. I have had burners and players that just don't work with certain brands. Also make sure you are burning at a lower speed like 4x
Jan 23, 2014 | Office Equipment & Supplies
Wrong region DVD player won't play a disc
Can,t be done with the one you have,
Nov 10, 2012 | Philips Televison & Video
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
May 06, 2012 | Sharp Televison & Video
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
Samsung dvd player wont read disk. says disc error
There a few causes of this.Check your manual to see what discs it won`t play.e.g finalised.,formatted
Moisture could have condensed inside the unit.Remove the disc and leave the unit turned onfor about 2 hours until the moisture evaporates.
Also check the region code and the appropriate dvd code to play on it.
Oct 20, 2009 | Televison & Video
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Sony dvd wont play certain discs
yes the sony dvd players is made for certain regions it wont play other discs that are not either region one or two new zealand i think is region 3
Apr 15, 2009 | Sony Televison & Video
Recorded a DVD on computer but will not play on DVD player
dvd players play only certain kinds of discs and formats. Older ones played -R's, most newer ones play everything. You have to look in manual, or on box before you buy player. If it won't play -R,+R, -RW,and +RW's I pass it by. Find out if your player is limited to certain discs. Some will play VCD and some will not. Some will play DIVX and some will not etc. Stick to the discs and formats your particular player is compatible with.
Nov 29, 2007 | iLO DVD Recorder DVDR05
63 people viewed this question
 Grubhead
Grubhead
