Question about 5002 2 Way Car Alarm with Keyless Entry System
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
  • bullraiders7
    bullraiders7 Nov 12, 2010
    that's not the problem I don't know one's. I plug in the blue
  • Viper Master
  • 625 Answers
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
Posted on Nov 12, 2010
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Door don't lock when put in drive
Yes, if you have the owners manual there should be a programming option in it to be able to make this happen. If you donot have the manual, let us know what model you have and we can try and figure it out.
Feb 27, 2014 | Viper Vehicle Parts & Accessories
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
2011 nissan sentra s door lock actuator wiring diagram
From the plug in door lock harness of the Viper alarm (green and blue): the green lock wire goes to the red wire of the vehicle in the driver kick panel and the blue wire goes to the pink wire in the kick panel. The light green with black wire from the Viper alarm goes to the white wire in the drivers kick panel. This white wire is the factory alarm disarm wire. It tests with the key in the door cylinder. Turn the key to unlock the door and the wire should register ground.
Aug 01, 2012 | Viper Vehicle Parts & Accessories
Viper remote won't open door lcks
Does the remote diarm the alarm? Do you hear the " chirp chirp" when you press the unlock button on the remote? If not, then the remote is defective or needs to be reprogrammed to the alarm. If you do hear the " chirp chirp" but, the doors do not unlock, then the issue is with either the wiring from the alarm or the vehicles power locks. Did it work before? Do you have power door locks?
Jul 21, 2012 | Remote Start System
Parking and cab lights don't flash where arming or disarming. Also Lights don't say illuminated when remote start is on. Did i turn this function off?
It's possible that the parking kight wire is no longer connected or, the (alarm's) fuse for the parking is blown. The parking light fuse for the 5701 is located behind the door on the alarm module.
Jul 20, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Feb 25, 2009 | Vehicle Parts & Accessories
Car is completely locked down
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
Jan 28, 2009 | 791XV The 791XV is a 2-way Security and...
Power door locks
You will need two power door lock actuators. They are pretty easy to install and would be wired to the new alarm system.
From what I see, decent DEI ones go for about 50 a pop. Atleast, in my area retail. If its something you are interested in, as of Aug 18th I still have two BRAND NEW in box that I never used on a client's old honda DX. Both the high powered versions.
Hit me up if interested sometime ddowling06 at g mail .com
Jul 08, 2008 | Viper Security and Remote Start System...
5002 2 Way Car Alarm with Keyless Entry System Logo
556 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Tre Elkins
Shehu Pro
Shehu Pro
Joseph Gallucci
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
