How to set ip address on hp designjet 1055cm plus
  • 7,733 Answers
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
Why has my hp designjet 1055cm has started printing everything with a red tint
Check helth condition of print heads, per form align print heads if nozzles are clogged replace print heads & cleaners..
Sep 09, 2011 | HP DesignJet 1050c plus InkJet Printer
I just purchased a new computer that has windows 7 and 64 bit and my hp designjet 1055cm plus inkjet printer driver is no longer compatible, Do you know of a driver that will work?
It appears that HP has linked the wrong file to the driver download on the website. I would contact HP and get the correct link so that you can download the driver.
Jul 11, 2011 | HP DesignJet 1055cm plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1055cm Plus system error: 04C300 001F0000.
Its either the EIO card, make sure its seated properly, or the hard disk drive has failed in your plotter. Try running the plotter with out the hard disk drive, it is static sensitive, so make sure your grounded before removing it.
Mar 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Cyan color not printing but ink indicator high
You probably have a bad trailing cable or bad carriage. Start by replacing the cable first. Parts available at: http://www.lpscomputer.com/p-2296-c6074-60418-designjet-1050c-1055cm-trailing-cable.aspx
Feb 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Cannot find MAC address for DesignJet 750c Plus
check your printer's menu settings you find menu for network settings there you can find ip addreses and MAC ADDRESES.
Aug 21, 2009 | HP DesignJet 750c plus InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
440 people viewed this question
jasbo
jasbo
