Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Windows 7 driver required for Maxtor personal storage 3200
SOURCE: Maxtor Personal Storage 3200 Hard Drive Problem:
Someone else figured this out, but I've seen a lot of people with the same problem. Hopefully this will help you with yours. This is for WinXP and Windows Vista. It worked great for me.
*** THIS WILL VOID YOUR WARRANTY ***
1 - Disconnect the HD from USB and power supply.
2 - There are 2 screws at the back. Unscrew and open the box. (The plastic is kinda hard to open be careful)
3 - Now you have a metal box in your hands. Unscrew and open it.
4 - Now you will see a HD and a controller board. There are 3 screws that holds the controller board. Take them out.
5 - Now slide out the hard drive and controller board out gently.
6 - Unplug the controller board (power socket and IDE socket)from the Hard disk.
7 - Look at the back you will see jumper settings. (Mine was set on Cable Select.)
8 - Take the jumper out and plug it to Master ON position. now put it all back together.
Posted on Feb 22, 2009
SOURCE: maxtor 3200 usb personal storage
Like many others, I had problems with the drive and tried some obvious solutions like swapping the old USB cable with a new one, trying different computers with XP, Vista, etc. and nothing worked. One solution I found was to open the HD case and swap the drive into a spare bay on your PC tower. I didn't want to go there since the case is very hard to open and I didn't want the hassle. So, the solution I tried was to replace the power supply. I saw this solution a few times in some forums so I figured to give it a try. I Googled the exact specs and found a comparable power supply at 12V Adapters (Aurora CO). It is not a Maxtor supply but I figured as long as the output was correct it may work. Just got the adapter today, plugged in the HD, and YES, IT POWERS UP and the XP at my work recognizes the drive! Now I have all my files available and accessible. Good luck to all, I hope this works for you. By the way, one lesson learned: BACK UP BACK UP BACK UP! Drives are so cheap now there is no reason not to (except for being lazy)!
Posted on Apr 17, 2009
  • 15 Answers
SOURCE: Maxtor 3200
There is a troubleshooter that describes steps for these symptoms on Seagates Knowledge Base website.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=188697
Posted on Sep 16, 2009
  • 15 Answers
SOURCE: power cord for maxtor 3200 external drive
The following site guarantees compatible replacement.
http://www.lcdpayless.com/productpage.php?productId=2511
I've been searching for a replacement as well. I found the specs on the original cord at the following site.
http://www.libertye-online.com/servlet/the-1642/new-APD-I.T.E.-POWER/Detail
12V, 2A, positive inner post, 2.5 inner diameter (ID) and 5.5 outer diameter (OD).
I don't think I would buy the exact replacement ADP brand fom the site above. Many have complained about it failing at the 2-yr point. I am considering the following replacement from the same website.
http://www.libertye-online.com/servlet/the-1218/new-Challenger-I.T.E.-POWER/Detail
NOTE: the input AC voltage range is different on this one, but it should still work in the USA.
There are other options on ebay.
http://electronics.shop.ebay.com/AC-DC-12-Volt-/88758/i.html?_npmv=3
Let us know if anyone has specific success with any of these or others.
How do I get Maxtor Personal Storage 3200 to automatically backup my Windows 7 hard drive daily?
You can get Windows 7 to do the backup for you. See http://windows.microsoft.com/en-CA/windows7/Back-up-your-files
Jun 13, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Green light is on but usb is not recognised code 43
Hello.
You didn't indicate what version of Windows you have, but if you have Windows 7 64 bit, Maxtor has not released a driver for Win7 64 bit which causes the error you are getting.
So, if you have Windows 7 64 bit, you will not be able to use this Maxtor drive.
Hope this helps.
Mar 02, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Old maxtor 3200, new computer windows 7. how can i make it work/
Maxtor manufacturer says that this drive is not ready for windows 7 and no driver had been issued. you will have to connect it to another computer to recover the data, or to use another computer in your network to access it and share the resource with your pc with windows 7
Apr 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have windows XP home edition and just reformatted computer. now the computer will not recognize the Maxtor 3200 personal storage device
Until you put an Operating System, Windows, Linux etc, on the formatted drive, it will NOT recognize the drive, it will not recognize anything...
Feb 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Window 7 does not see Maxtor driver
Does it work on another computer?Try checking it on another computer.Windows 7 usually see all usb devices pluged in.Check the Maxtor website for drivers as well.
Good Luck
Jan 17, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I need driver for Windows Vista
Hi i cannot find the driver either , but what you can try is Download XP drivers for it , then right click and run in compatibility Mode for XP , and it should install
Dec 30, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Will maxtor 3200 work with windows NT and if so where do you find drivers
Here are the requirements according to Maxtor: Hardware and Operating System Requirements for Windows PC ? Pentium III-class equivalent processor or later ? Windows 2000 or XP ? 128MB RAM or more as required by operating system NOTE: Macintosh Systems are NOT supported with this product. Here is a link to the User Guide: http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/ps3200_users_guide.pdf
Dec 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
How can i install the maxtor personal storage 3200? are there any drivers that i need to install?
You do not need any driver. This device is plug and play in Windowsmag-glass_10x10.gif XP. If it doesn't work then you probably have a USB problem. Have you checked in Device Manager to insure the usb port is working properly and is compatible with the drive, eg: usb 2.0 or usb 1.1?
for any further information refer to this link :
http://forums.driverguide.com/showthread.php?t=19966
Thanks,
Prince
Aug 06, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 ... Problem
Check the manufacturers website, as all drives no matter what should come with drivers of some sort. this is the most likely cause for what is wrong.
Jan 17, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
159 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
