Question about Texas Instruments TI84Plus Graphic Calculator
Can the face plate be changed on this calculator?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
No. The faceplate can be changed on the TI-84Plus Silver Edition, but not the TI-84Plus. You can customize the front of the calculator with GraphiTI, available at
http://education.ti.com/educationportal/sites/US/productDetail/us_graphiti.html
Posted on Nov 09, 2010
Kenwood kdc-mp522 face plate goes out when pushing on buttons
Clean the contacts on the back of the face plate and where it connects to the deck.
Mar 17, 2016 | Kenwood Car Audio & Video
Key function for fx570ms
Look at the face plate of the calculator. You should be able to recognize the functions.
Apr 24, 2014 | Casio FX570MS Scientific Calculator
NCr and nPr
Look your calculator in the face. Find two keys one marked nPr, the other nCr. There is third key nearby with the exclamation mark (n! or x!)
If the markings nPr, nCr,n! ARE ON THE KEYS, you do not need to press [2nd F] or [SHIFT] to access the functions.
If the markings are on the face plate of calculator you must press [2nd F] or [SHIFT] then the appropriate key.
To calculate 10P3 you enter 10, press [nPr] or [SHIFT] (nPr), enter 3 and press [= or EXE]
Mar 11, 2014 | Canon F604 Scientific Calculator
Is it possible to change the faceplate of the TI-84 Plus calculator?
Yes, you can change the faceplate of the TI 84PLUS Silver Edition only, not the TI 84 Plus. Face plates are available for purchase at the TI online store.When you go the online store, select the country, then the calculator model. You will find them under accessories for the TI 84 Plus SE.
Aug 15, 2011 | Texas Instruments TI-84 Plus Silver...
Profit Calculator KS1000, how do I change the dead battery? Where is it?
Turn calculator over
Remove two visible Phillip screws
Gently pry up and remove rubber feet on all four corners-remove screws
Button cell battery (original: VINNIC L1131, replacements: Energizer 389/390 or Duracell D390)
Location: upper right hand corner under metal battery clip
To replace battery: gently pry up left tab and slide new battery with + side facing up (writing visible).
Gently push tab back down
Next: Look at circuit board, locate double arrows
Follow directions: "please press "RESET" after replacing battery"
I just touched the metal flow solder plate (small circle with squiggles) above the words "RESET" with a small screwdriver
TA-DA...it works
Nov 17, 2010 | Office Depot KS-1000 Calculator
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
I need to change the battery on the tI30-xa calculator. I need to know the size and how to change it.
Remove slide cover. Place calculator face down. Using a small Phillips screwdriver, remove screws from back case. Remove back case. Remove discharged batteries. Caution: Avoid contact with other calculator
components while changing batteries. Install new batteries positive side up, as shown on diagram inside case. Replace back case, and then replace screws.
May 19, 2010 | Texas Instruments TI-30XA Calculator
Face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Jan 20, 2009 | Alpine CDM-7874 CD Player
Kdc 215s
its the face plate just need to take out clean with little rubbing alcohol these kinda face plates has a scrolling feature that i donot like very much face plate just needs to adjusted back on sterio mount
May 07, 2008 | Kenwood KDC-215S CD Player
Psp anolog button faulty?
You just remove the face plate again and check it now your PSP is working OK if so there is some misalignment while placing the face plate on PSP and suppose your fault still remains same without face plate also then there is a possibility of Analogue button is being damaged which should be changed.
Feb 27, 2008 | Sony PlayStation Portable (PSP) Console
Texas Instruments TI84Plus Graphic Calculator Logo
35 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
