Question about HP Compaq Presario V2000 Notebook
My computer just turned off
I was installing a printer to print some directions out and when i try to connect a cable on the wrong output the computer just shut off and now it's not turning back on. What sould I do?
  • 385 Answers
Unplug the cable, the power adapter and take out the battery. Leave unplugged for about ten to fifteen minutes. It might have caused a short in the circuit. If it still doesn't help, then the cmos battery may need to be reset.
Let me know what happens.
Lolita
Posted on Jun 16, 2008
My Epson Label printer is showing as not connected when its connected, when trying to set up or add as new printer.
What shows mac and ip address ? printer or pc ?
If the printer displays them, it means the printer in connected to router electrically.
Check subnet mask and gateway address.
Could be set wrong if the router is not on DHCP.
I guess the issue is in the ethernet components / settings.
Start isolation by elimination of the following
1. Computer -
2. Wifi connection to the router (or)
3. Patch cable connecting computer to the wall -
4. Router -
5. Patch cable connecting the printer to the wall -
6. Printer -
The LAN printer cannot connect to Computer (PC/Mac) directly unless you use a Cross over cable.
Sep 11, 2016 | Epson Tm C3400 Securcolor - Label Printer...
Tip
How to troubleshoot printer issues?
<p><b>General Printer Troubleshooting:</b><br /> <ul> <li> Make sure the printer has power and is on-line. If you are using a manual printer sharing device, make sure the switch is set to activate the correct printer.<br /> <li> Turn it off and on again to reinitialize any internal settings that may have gone astray.<br /> <li> Ensure that the tape that seals the cartridge ink port is removed prior to installing the cartridge. <br /> <li> Use the printer's own self-test, according to the manufacturer's recommendation. If it fails, you have verified that the problem is within the printer. If the print head is not moving at all, the transport motor may have failed.<br /> <li> If the printer that you are using is not set as the default printer in Windows or the printer driver is not installed, the printer may print garbled characters. You may also receive errors when you attempt to print from applications.<br /> <li> If the printer passes the self-test, try a test print using the Print Screen capability within DOS. If the Print Screen fails, you know the problem is in the relationship between the printer and the computer. Inspect the cable and the cable connections. Replacing the cable with a known good cable is worth trying since cables are so frequently the source of printer problems. Cables can fail with broken wires, loose or broken pins, or incorrect pin-outs.<br /> <li> If the printer is connected to the computer through an add-in device, remove the add-in device and connect the parallel cable to the printer and then directly to the port on the back of the computer. Some examples of add-in devices are: switchboxes, parallel port scanners, external disk drives, external tape drives, security lock keys, or external CD-ROM drives. Some add-in devices may interfere with proper communications with the printer. Try printing again. If the printer prints successfully, the cable may not have been connected properly, or the add-in device may have been interrupting communication with the printer.<br /> <li> If the combined length of the cables connecting the add-in device and the printer exceeds 10 feet, communication can also be disrupted. In addition, the software that controls some add-in devices may take control of the printer port interfering with any other device attempting to use the same port. In some cases, the software for the add-in device should be disabled or uninstalled. Remove any add-in devices and uninstall the software for those devices, then try printing again.<br /> <li> The message "out of paper" is sometimes erroneously reported when there is plenty of paper, and can indicate a physical problem with the printer.<br /> <li> If the printer port is not properly identified in CMOS, the printer may not function properly and you may receive errors when trying to print. Check your User's Guide on how to enter CMOS. Once in the Setup utility, locate the LPT1 settings. The address setting for the LPT1 port should be 3BCh or 378h depending on what kind of video card you have. The IRQ setting for the port should be 7 and LPT1 should be enabled in order for the printer to print correctly.<br /> <li> If the Print Screen succeeds, the problem may be with your application or its configuration. For example, your application may be set up to direct output to a file instead of the printer, or you might be directing the output to the wrong communications port.<br /> <li> Try connecting a different printer to this computer or try connecting the printer to a different computer and print a test page. If this printer works when connected to another computer, there may be a problem with the port on your PC. If this printer does not work when connected to another computer, there may be a physical problem with the printer. </li></ul>
on Jan 21, 2011 | Office Equipment & Supplies
49 error
49 error means firmware error..
solution:
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error.
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again.
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
My epson stylus tx 121 doesn't print..... it says ur printer s not ready... but everything s ryt at my end.... i need some solutions
First how are you connecting to the printer? Is it a direct USB connectionor are you using a USB hub or print server (sometimes part of a router)? If a USB hub is in use, is it a USB powered hub or a self-powered hub (AC adapter)? (Make sure that the printer has power and is turned on. Also make sure that you have printed and scanned a calibration )
If you are not using a direct connection, try a direct USB connection. Use a different USB cable and try different ports (some ports have lower power throughput than others). Make sure that you have the correct driver for your OS. (The full software is useful for other issues.) See http://www.epson.com.ph/epson_philippines/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_TX121 for the drivers.
Try uninstalling the current printer driver and then disconnect your data cable (USB). For Windows, press Start and open the Devices and Hardware control panel (Printers and Faxes in XP) from the right hand column. Right click on the printer and select Uninstall (or left click and choose Uninstall from the Menu bar). Reboot the computer and install the Epson printer driver before reconnecting the USB cable. (Otherwise you can get the OS driver that may not work as well.) Remove your data cable from both the computer and the printer and turn off both devices. Unplug the power cord from the printer and the wall outlet. Wait a few minutes before reconnecting the power. (This will reset most printers if there is an error in the printer itself.)
If you are using a print server and the direct connection worked, check the installation information for using the print server. Not all printers are compatible with certain print server drivers and you can have a conflict.
If a direct connection to any of your computer's USB ports does not work, check if other USB devices work. If not, try updating or uninstalling your USB controller (in the Device Manager for Windows - Start > Control Panel > System and Security > Device Manager, scroll down to the Univeral Serial Bus controllers). Then reboot your machine and see if the correct driver installs. Alternatively, check your computer manufacturer and see if there is an update for your USB driver.)
If the problems persist, you may have a bad USB port on the printer. Please add a comment with the type of connection between the computer and the printer.
I hope this helps.
Feb 23, 2012 | Office Equipment & Supplies
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
How to scan soemthing onto a computer
Do you have the full-featured software driver installed? (Installed before connecting the printer to the computer.) Then you have the option of initiating the scan from the computer or the buttons on the unit. (The HP Digital Imaging Monitor Windows System icon should be in your system tray. If the program has been closed, restart the HP Image Zone software or reboot the computer.) There is a Start Scan button on the printer which should launch the HP software. Alternatively, start the Image Zone software and there should an option to start the scan.
These directions will only work if the computer and printer are both on and communicating with each other. If you get an error, try a new USB cable and try using a different USB port. If using a USB hub, try connecting to the computer directly. (If using a print server, try a direct connection. Check if the print server supports bi-directional communication; many only support the print functions not the scan options.)
I hope this helps.
Mar 22, 2010 | HP PSC 1510v All-In-One InkJet Printer
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Printer is on but not responding to the computer. Message says make sure your printer is turned on
Hello
Hope this is of use.
1) Does the printer show under printers if not its not installed. Intall using the software CD that might have come with it. If it is installed de-install it and re-install after checking points 2-4 below. 2) Is the printer connected directly to the PC or through an external hub ? assumming its using a USB connection. If through a hub disconnect it and connect directly and try again. If already connected directly use a different port. 3) Try a test print. If it works the problem may lay with the application you are running if it doesn't then make sure all connections are secure. If all appears to be OK change the cable connecting the printer to the PC. 4) Are you using a Parallel cable of the ribbon type if you are change it for non ribbon type. Ribbon cables are not good yhey tend to break.
Lastly have you had a successful print or is this the first attempt. If First attempt and all connections are secure then re-install the printer software.
Aug 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
