Question about Garden
Laboring to turn over - -- New battery at 13V ,cleaned terminals, posts and chassis grd.Jumping from car doesn`t help. JUSTS GRUNTS THROUGH ONE STROKE. 8 HP toro rider
  • 718 Answers
If you have an OHV engine you rockers are most likely out of adjustment, especially if you have not had this done ever. If you don't know what I am talking about take it to your local repair center or reply and I will try to talk you threw it??!!!!
Posted on Nov 09, 2010
  • vince janis
    vince janis Nov 10, 2010
    GO to smalleng.com they have a video on how to adjust rockers, even if you have a little mechanical ability you can follow this video. Good Luck
I have a 2004 Sea Doo GTI LE That clicks like a bad batt. I have a new batt installed. Ocassionally it will turn over like it should but only for a second. Any suggestions.
There is a bad connection at the battery terminals or cable connections, check the battery posts and cable terminals are shiny clean, check the earth cable is clean and tight at the chassis , check the cable to the starter motor is tight and clean, if all is good there the starter may be at fault.
Feb 27, 2017 | Cars & Trucks
Head lights dome lights and dash lights all flicker. has new alternator and battery. what else could case this?
check the earth strap of the battery to chassis/ engine for clean and tight. Check battery terminals and posts are shiny clean and tight.
Jul 18, 2014 | Cars & Trucks
IS THERE A FUSIBLE LINK BETWEEN THE BATTERY AND STARTER ON A 95 FORD EXPLORER?
hi there please check all ground /negative wires from battery to engine and chassis are secured firmly and check all contact points and wires for corrosion , have the battery tested although new.The next time the problem reoccurs remove battery and fit fully charged battery if this resolves your issues electrical wires and components should be fine
Aug 17, 2017 | 1995 Ford Explorer
Key turns in ignition but nothing happens battery good and lights come on do i need a new starter and how do i get to it to remove old one
First troubleshoot. Have to tried jumping the car? Are the battery terminals clean and tight? If all this is good, you can try jumping the solenoid to see if the starter/solenoid is bad. I have posted procedures at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines.
Please let me know if you have questions. If you decide the starter is bad, there are instructions here for replacing it: http://www.fixya.com/cars/r5973094-starter_replace
Sep 25, 2010 | 1996 Nissan Sentra
Negative Post for Battery
For jumping connection it is under the hood, directly between the red capped post and the driver side. It says GRD on the post. Good luck.
May 18, 2010 | 2007 Pontiac G5 Gt Coupe
I have had problems starting my vehicle. sometimes it takes 5 to 30 attempts of turning the key to even get it to start. the problem seem to not be as apparent when parked downhill on a slope, but now it...
it seems the starter is bad. you have the classic symptom. but first, clean the battery terminals with a battery terminal cleaner, a wire brush specifically designed for it. possibly a loose cable connection to the starter. make sure battery terminals are tight. if corroded, disconnect the cables and use a wire brush to clean heavy build up and then pour very hot water over them, almost boiling, the corrosion will disappear. if you have a radio that requires a code with regards to theft, make sure you have the code.
Apr 20, 2010 | 2001 Oldsmobile Intrigue
I have a 2006 Mazda 6 that won't start. It just clicks even when jumping it and the gauges bounce up and down. Even after you turn the key off.You can hear some clicking under the hood for a while after...
This may sound silly, but pull the cables off the battery and clean the posts and terminals really well with a wire brush or post/terminal cleaning tool. (these are REALLY cheap at the parts store and work wonders!) This may be your problem. Corrosion = poor connection. If not that, try new battery. Good luck.
Dec 05, 2009 | 2006 Mazda 6
2004 Nissan Armada 5.6 Liter. Parked it and it
Did you remove the battery terminals and clean the battery posts and the terminals interiors with a special cleaning wire brush (from an auto parts house)? At this point, you may need to recharge the battery overnight at 4 to 6 amps. Buy a tube of anti-corrosion grease and smear over the battery posts and inside the terminals. Make sure you wash your hands after working on the battery, or you may wind up with strange holes in your clothes. As a test of your charging system, measure the voltage across the battery terminals while the engine is running (high idle)--you should measure about 13.5 to 14.5 volts. With engine off, it will measure 12.6 volts. If the running voltage is 12.6 or less, the alternator circuit is in trouble and not charging.
Aug 18, 2009 | 2004 Nissan Armada
When I turn the key, all I hear is the clicking sound. Battery appears to be okay, had it checked a month ago by Sears. A jumpstart doesn't work either.
It's the starter. You can probably get it started by finding a long steel rod, or a long garden rake stick(with the rake removed)...get under the hood, find the starter, and tap hard on the starter while someone in the truck is trying to start it. I mean really bang on the starter! It should start, but you will have to change the starter eventually.
Give it a try.
EW3
Jun 03, 2009 | 1996 Toyota Land Cruiser
1994 Chevy cavalier short circuit
possible SHORT ON THE CHASSIS.CHECK FOR WIRE TOUCHING CHASSIS,ALSO CHECK THE STARTER CABLE.ALSO CHECK DOOR A DOME LIGHTS,AND ALARM.YOU HAVE AN AFTER MARKET STEREO?
Jan 01, 2008 | Car Audio & Video
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
