Question about Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio
My FT60R is not showing the battery voltage when I turn it in and it is not charging the battery TI2JYA JAVIER
Lifefitness 95xi wont turn on
Check the speed sensor to turn on the elliptical, or send the lower board to repair with www.xtremefitnessservice.com, ask for Javier
Sep 26, 2014 | Life Fitness 95xi Elliptical Crosstrainer
Battery not charging
It shows full voltage while running because its circulating the power. If its not charging, depending on the bike you have, its the stator or regulator. These are basically the alternators for bikes. Just take it to a shop and theyll usually check it for free. It will just drain the battery everytime you run it until you get those replaced
Mar 31, 2014 | 2006 Hero Honda Passion Plus
Camileo h10
The charging lamp burning, does not give any guaranty about the quality of the battery. It only shows power is applied to the battery.
Your battery although it still can have a little charge, can be on its end of life. The only way to be sure the battery is still fine is to measure its voltage with a multi meter. If you do so, the voltage should be above the voltage printed on the battery. The nominal voltage on the battery is the voltage it will have when working in he camera. I think you have to buy a new battery. And please when you have a new battery, charge it several times a year, even when you don't use it between the holidays.
Jan 30, 2014 | Cameras
My car batterie not charging ?
Measure the voltage of your battery using a multimeter.if it show expected output voltage,wait for sometime and check multimeter volt reading.if it again show expected voltage,the battery may have no problem and the problem is with the charging circuit.if the reading is lower than expected voltage the battery is damaged.
Checking charging circuit:
1.check dynamos.
2.check wire continuity.
Nov 07, 2013 | Cars & Trucks
Dead Yaesu FT60R
There is probably an internal fuse which has blown. Send it to the Yaesu service center for repair. They're reasonable and will do good work...
Jun 27, 2013 | Yaesu Ft-60r Dual Band Handheld Vhf / Uhf...
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
I have a 10KW SIEMENS generator Model #0059090 - Cat#ASGNO10RBS, it was installed May 26-2011.Generator workrd fine after runing all the test required. We had a very short outage less then a minute, after...
Most of those chargers have a fuse in line between the battery and the charger which you should check. They are two stage chargers meaning when there is a large voltage drop, they go to a high rate charge until battery voltage reads about 14.3 - 14.6 VDC then drops to a float volatge and normal float voltage should be about 13.33 VDC. When they go to a high rate the light turns red, when they go to float the light turns green. When the fuse blows the light stays green because it doesn't see any voltage but the charger isn't doing any work.
Jun 23, 2011 | Generac Electrical Supplies
1998 k1500 5.7l 105a alternator. replaced
Now change the sulfated batery for a new one.
Vitally
Sep 09, 2009 | 1998 Chevrolet K1500
Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio Logo
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
