Question about GE Ovens
What does f o f 7 mean - GE Ovens
  • GE Master
  • 12,061 Answers
Well that's an Error Code, that indicates that you need to replace both the touch pad and the Controller Board replaced.
http://applianceguru.com/forum1/4294.html
have a look at this post above it discusses the matter directly.
Also have a look at the web site below, it has all the error codes explained.
http://www.repairclinic.com/Fault-Codes
You most likely need to call a professional, to attend to this matter...ask for a "Quote" before allowing repair work to commence.
Contact a local or head office from GE, ask them for a referral to an authorised service center, and go from there.
It maybe beyond economic repair, so be careful, the keypad alone is around $300!
You could try to DIY, in which case you also need to get a service manual, to show you how to repair the unit, and more importantly, the parts numbers for replacement parts. It is not a difficult job, to replace these items.
It may indeed be better to put any monies that would have been used for repair towards a new unit, with a warranty? Of course that's your call.
Posted on Nov 08, 2010
I lost my manual for Snappy Chef. I do not know if E06 appear what does it mean.
LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
Feb 02, 2015 | Ovens
I have a kenmore elite oven what does an error code F-3 mean
Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Oct 03, 2011 | Kenmore Ovens
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
What does the oven control pictures on the control mean , picture of fan understood,
what do the pictures mean on the dial indicator on a eurotec oven mean?
Dec 16, 2010 | Ovens
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Says f1
F1 error code usually means that the oven temperature has exceeded 590 degrees. Usually this means that the oven temperature contol sensor ( or thermostat) has failed allowing the heating element to overheat the oven.
To correct this you will need to fit a new sensor. Sometimes the error code can mean a temporary glitch which may be cured by turning off the power for 30 mins and then resetting but if the problem persists then a new sensor is the answer.
Jan 07, 2010 | Kenmore Ovens
What does e1 f3 fault code on my oven mean
F3 means your oven temperature sensor is open. you will need to get it replaced. hope this helps.
Oct 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Maytag oven says sabBATH what does it mean?
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
Sep 16, 2009 | Maytag 30" Built-In Single Electric Wall...
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
74 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
