Question about Brother MFC-465CN InkJet Printer
How do I change the default setting for this: MFC will stop Color/Grayscale print operations when one or more of the ink cartridges are empty.
  • 26 Answers
SOURCE: Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Posted on Dec 15, 2007
  • 30 Answers
SOURCE: Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Posted on Feb 06, 2008
  • 1170 Answers
SOURCE: can you force a printer to print in grayscale?
Yes, you can bypass the color printing. The software you are using for printing can help you change from colour to gray scale or adjust it in the printer properties.
Posted on May 10, 2009
komguy
  • 2306 Answers
SOURCE: I would like to print black with one color cartridge empty
If you take the empty cartridge out and put a small piece of electrical tape over the little window on the front, the printer will think the ink is full.
Posted on Jul 20, 2009
  • 630 Answers
SOURCE: wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Posted on Aug 22, 2009
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Jul 19, 2009 | Office Equipment & Supplies
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Brother 210C One colour cartridge empty, want to print a black and white fax
Yes, if you dont need the color anymore in future:
You can cheat with empty c/y/m carts by sticking some dark but very thin adhesive tape around the nose (see picture).
After that the printer logic expects the c/y/m carts always as full.
But you cant print any colors within the next 2 weeks anymore because air will dry out the print head (and destroy the color nozzels)!
See brother homepage for instructions on how to print in grayscale only!
Jan 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-465CN InkJet Printer Logo
273 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
