Question about Gateway (4000782) Motherboard
Computer not working
My computer just stopped working with no reason behind it..The screen started to turn different colors and the mouse stopped working..I shut down and powered back on and there were 3 beeps but nothing would happen on the screen. Will i lose everything on my hard drive??
  • 385 Answers
This is usually a problem with memory, either video memory or ram. Try another good ram first, if nothing changes, then try a different video card.
Good luck and hope this solves your problem.
Lolita
Posted on Jun 16, 2008
WHY DOES MY COMPUTER FREEZE UP?
WHAT ARE THE SPECS.X32 OR X64 ?.HOW MUCH MEMMORY?.
HOW MANY PROGRAMS ?
INFORMATIONEN IS IMPORTENT.
Aug 03, 2014 | E-Machines eMachines Desktop PC
Mouse keep getting stuck
Is it an optical or laser mouse? Try to use another mouse and check if the problem is with the PC or the mouse.
Mar 05, 2014 | Sony Vaio Pcg-7h1l Pcg-7n2l Black Laptop...
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Stop mouse blinking when start open windows and over screen color resolution and size
make sure the mouse Ps 2 or the usb plug has a good seating if applicable or if its batteries that are good
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 20, 2012 | Computers & Internet
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Aug 11, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
It has stopped working; I can see the cursor on the screen but there's no response. I have rebooted, but it has made no difference.
I have the same problem. It worked fine for over 7 years now. Yesterday I put it into the charging device after I switched off the Mouse. Started to charge. In the moring I took it off and slide the Off button to On. The battery indicator shows full. Windows 7 recognize it but no mouse movement. I tryied 2 different computers (both with XP) and the mouse is recognized but not working. I tryied to look into the laser lens but no red light there.... I also tryied to put it into charghing the Red Status Lid for 1 second and after it goes all green.
What to do???
Oct 25, 2010 | Logitech MX1000 Laser Cordless...
Frozen cursor
do you have a wired or wireless mouse?
Have you tried attaching a different mouse to your computer?
What is the brand name of your mouse?
Try booting your computer in Safe Mode. To do this, after turning on the computer, press F8 button several times. You will see a screen that will ask you to boot normally, boot in Safe Mode or boot in Safe Mode with Network Connections. Select Safe Mode.
See if your mouse works then.
Check back with me for further help, if needed. There are additional things you could try.
Oct 08, 2009 | E-Machines eMachines Desktop PC
Computer wouldn't wake up, now erratic screen
Try this:
Unplug the computer.
Remove the battery.
Leave battery out for at least 60 secs.
Replace battery and plug it back in.
Try to turn it on.
Jan 12, 2009 | Microsoft Windows XP Professional
98763 stop working
Did you try putting in new batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Normal 0 If it’s a wireless GE mouse turn it on by pushing the button on the bottom and hold till the red light comes on. Assuming the computer is running, press the Blue light on the Receiver and press the button on the bottom of the mouse and it should start tracking on the monitor.
Hope this helps. Bud
Jun 06, 2008 | GE Wireless Optical Mouse
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Gateway (4000782) Motherboard Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
