Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Model 350 was running fine, now seems like fuel starved after 4- 5 minutes of running. did fuel filter, fuel line, &new plug.
    Brigadier General:
  • 4,088 Answers
Check the fuel tank vent for plugging. Make sure the carburetor is securely fastened at all points. Be sure to use fresh fuel/oil mix (50:1) and shake the container thoroughly each time just before adding to tank to prevent oil starvation. Check the muffler for plugging. It's possible that the diaphragm in the lower chamber of the carburetor has failed--it should be flexible with no holes or cracks. Hope some of this helps!
Posted on Nov 08, 2010
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
Cub Cadet HDS-2135 13B-214F100, runs great for 45 - 60 minutes then cuts out, only run on full choke, cannot mow but runs. Cools down works fine again
check the fuel filter and fuel line. it may need to be insulated to protect from heat. running on choke means it is starving for fuel . take the carburetor off and clean it real good. be sure the fuel lines are away from heat source.
Jun 09, 2016 | Cub Cadet Garden
Chainsaw wont stay running Runs 30sec to about 1 1/2 min seems to be starved for fuel
Initial carb setting is 1 full turn out on both low and high side and retry. If no difference, then turn the low side out and additional 1/4 to 1/2 turn CCW. If that makes no difference, then it's time for a carburetor rebuild.
Feb 24, 2015 | Garden
I'm having trouble starting the car. When it idols the RPM's pulsates up-and-down and then it stalls. Once under way the car seems to run fine but without any warning it will die as I start to
check air filter, might be plugged, [dirty so engine is starving for air.] check fuel lines & filters, dirt blockage need replaceing, check for fuel leaks in lines etc, uses fuel & then sucks air causing it to stop, listen to see if fuel pump is running properly & not stuttering could be short in it's wiring
Dec 16, 2012 | 1994 Mercedes-Benz E-Class
How to get to the fuel filter on a Poulan 2150 Chainsaw
A blunted hooked rod through the fuel filler hole should snag the fuel hose. Draw it slowly toward the opening and a filter should become obvious on the free end. The manufacturer recommends an annual replacement.
It sounds to me like your fuel vent may be plugged. How long does it run before it starves out? If rotating the saw and loosening the cap causes it to operate correctly it is a bad vent. If it starves in less than a minute it is likely a defective fuel delivery hose or outside chance a leak in an impulse line somewhere.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 05, 2010 | Garden
Will not run under load, seems to be starving for fuel. When I leave it for a minute or two, I can start it and work with it for a minute or so then it sees to over rev before cutting out. If I start it...
Check the fuel filter in the tank for plugging. Check the fuel lines for kinks, rotting, or splits. Check the muffler and air cleaner for plugging. Make sure all the screws and mounting nuts are tight on the carburetor. When these things look ok, then turn the H needle jet CCW about 1/2 turn, start the engine and let it warm up. Open the throttle fully--the engine should be 4-stroking now. Proper adjustment is when the engine will 4-stroke, but immediately 2-stroke when cutting. You may need to turn the H needle somewhat CW to achieve that condition. Hope this helps!
Apr 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
1997 chevy silverado 1500 350 vortech, new fule pump not working
before you drop tank again, check fuses & relay.then disconnect fuel line @ filter turn key to on position should hear fuel pump run and get gas stream out of line. if no flow from line new pump faulty be sure & remove negative battery cable first good luck.
Jun 04, 2009 | 1999 Chevrolet Silverado 1500
Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
May 30, 2009 | Farmall Cub Tractor Radiator
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
174 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Mike Squire
Jay Finke
Jay Finke
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
