Question about Moen & Replacement Cartridge
I just replaced the cartridge in a Moen single handle faucet which was leaking. Now when I push the handle down to turn off the water it pushes back out and a small stream of water continues to run. If I put some pressure on the handle the water will shut back off, but as soon as I let go the stream resumes.
    Genius:
  • 1,015 Answers
I have experienced this problem a few times in twenty plus years in the plumbing business. What I would do is get a moen brass cartridge and give that a try. Hope this helps you thanks
Posted on Nov 17, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    My kitchen faucet is a single handle Moen and is approximately 20 years old. Lately it has been acting up which I have been ignoring in the hope it would heal itself. It has been difficulet to turn the...
    It may just be that you need a new cartridge. If you can replace cartridge without to much problem I would do that. Depending on your water quality the cartridge may be very hard to remove on a faucet that old. Also if the handle actuating hole is worn very much you may have to replace it also. By the time you buy parts you may have half or more of the price of new faucet, I would recommend that you replace faucet. Hope this helps. Thanks
    Nov 17, 2010 | Moen Plumbing
    I have a single handle Moen shower faucet. Pull to turn on. Turn clockwise for cold. Turn counterclockwise for hot. It does not leak but it is hard as hell to pull out when I turn it on. The house was...
    If it is hard to pull out or push in the valve then you will need to replace it. On moen valves you can not rebuild the cartridge you can only replace them. A new cartridge will cost you around 15 to 20 dollars.
    Also I would tack the cartridge with you when you gao and buy it because they make 2 different ones.
    Good Luck and please rate 4 thumbs up for the free answer
    Sep 21, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
    The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
    May 13, 2010 | Moen & One Handle Tub & Shower Faucet
    How do I repair a leaky Moen faucet handle. When I
    It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
    Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
    Replace cartridge in Moen kitchen faucet and now
    it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
    turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
    Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    The single handle fauchet will not stop running water.
    Replace cartridge and insure that the C clip is not missing.
    Sep 11, 2009 | Moen & Posi-Temp Single Handle Shower Or...
    Difficulty shutting off faucet after installation of cartridge
    sounds to me like you did not engage handle properly the moen has like a half moon in handle that has to go on just right and can be a little tricky if it went on easy its not on right
    May 03, 2009 | Plumbing
    Moen & Replacement Cartridge  Logo
    118 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
