Question about Sunforce 44444 12volt 400watt Wind Generator
How do I remove dried epoxy glue from two pieces of metal without damaging the metal??
    Problem Solver:
  • 11 Answers
Most epoxies will soften and crumble when heated. This is the easiest way of loosening epoxied threads etc.
Posted on Nov 17, 2010
My left earbud was hit against my desk and the circular metal piece disconnected from the speaker, how do I fix this?
push it back on and if it does not stay,use a very small amount of A-B epoxy glue. Apply glue with a sowing needle.
Apr 30, 2016 | ifrogz EarPollution Plugz Headphones
Tip
Making a Dual Final output on cheap CB radio.
Get you a cheap radio Uniden/Cobra etc. Buy you a 2SC2078 or 2SC 2075 from RADIOSHACK for around $4 or take a good one from another radio. Solder to your already 2SC2078 final (fit it to match up) make sure you use a strong epoxy glue,(Liquid nails or silicon glue) Glue it to other 2SC2078(Let dry 24 hours - 48 hrs.) Wait couple days to turn on power. This is the dual configuration which produces more (Amperage) to (Wattage) If it gets HOT!!!....ADD Heatsink to Second 2SC2078(Just a piece of metal glued to front of it. DO NOT TRY THIS ON YOUR BEST RADIO YOU ARE PRESENTLY USING. THIS IS AN IDEA TAKING FROM OLD AGE (Am radio transmitters-in the day).
on May 01, 2011 | Radio Communications
I need to reattach a couple of plastic pieces that fit on the under side of the seat on my motorcycle. The pieces have broken off as the bike was probably dropped at some time. The two pieces plastic...
There is a two part plastic glue found in hardware stores, but if you are trying to end join two narrow pieces together without adding a backing piece, it won't work.
Dec 17, 2014 | Adhesives, Coatings & Sealants
Kitchen drawer, particle board repair.
It is far better to replace the drawer front altogether. Glues and adhesives actually make particle board swell and cause it to disintegrate so if it is splitting there is no sound way to glue it back together and retain any structural integrity. I suggest taking the drawer to a local cabinet maker and have them repair it by duplicating and replacing damaged pieces.
Dec 01, 2014 | Garden
How to remove superglue from stretch fabric skirt please
Try an acetone-based nail polish remover. Be aware that you may already have damaged the fabric.
Jun 17, 2013 | 3M Scotch Single Use Super Glue 12 Gram...
How to seal a small hole inside the door of dishwasher from the metal end of the top rack hitting along the inside of the door.
Remove the epoxy, and clean the area with alcohol.
When dry, add a small amount of GOOP adhesive to the area. The door must be left open for at least 12 hours for the adhesive to set enough to prevent sagging. unit should not be used for a total of 24 hours for complete hardening.
The GOOP adhesive is available in the glue/adhesive sections of hardware and big box home center stores.
As an appliance tech I have used this product for many years on tubs of all types to save my clients from expensive repairs. It holds very well, yet can be removed if need be. As time goes on, you may need to add a little more to cover any additional wear that may occur.
Let me know if it worked out for you.
Apr 13, 2017 | Frigidaire Dishwashers
Interior rear view mirror fell off my 98 BMW 540i
There is a small set screw that holds the mirror to the small metal button. Most vehicles use a small Phillips screw but some use a Hex Key Wrench (Allen Wrench) type screw. Slide the mirror off the button. Make sure not to remove the glue before you put the button back on. Trace around the glue with a grease pencil on the outside of the windshield before you remove it. So you know exactly where to replace the button. You can buy a Rear View Mirror Adhesive Kit for around five dollars.
Jan 10, 2012 | 1998 BMW 5 Series
Rear view mirrior fell off.....how to you put it back?
Auto parts stores sell "Rear view mirror adhesive" - special glue for mirrors. TIP: Follow instructions to the T or you'll be doing it over.
Mar 15, 2011 | 2000 Hyundai Accent
Need to replace rear felt seal what to do any glue needed
The felt seal replacement kit should come with some high temp. epoxy to glue the seal back on. The epoxy is quick drying and can be very messy. The easiest method to install the seal is to remove the drum from the cabinet and place it on its end with the felt seal UP. Remove the old seal and clean the old surface. Apply a thin film of epoxy all the way around the perimeter of drum and spread using an old paint brush or cotton swab (something you will want to throw away when done. Only apply enough to the surface area where to seal is applied. While the glue is still tacky, begin applying the seal to the drum, slowly working your way all the way around the drum. The glue is fast drying, so you will only have a few minutes before it begins to harden. Once the seal is in place, allow the glue to set up for a few minutes and reinstall drum.
The instructions come with the repair kit. If you post back with your MODEL NUMBER, I see if I can provide you with a part number.
Aug 24, 2010 | Dryers
Sunforce 44444 12volt 400watt Wind Generator Logo
47 people viewed this question
Top Sunforce Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Sunforce Electrical Supply Expert? Answer questions, earn points and help others
