Question about Refrigerators
The water is freezing in the chute coming down to the ice maker from the water line before it can get into the ice slots. what could be causing that ????
  • 1,344 Answers
Sometimes water molecules will gather there over time and eventually will bulid up. chances are you have a plastic chute and those tend to gather ice easy opposed to the rubber ones. Either way, if you pull the chute out from the back of the refrigerator and clear the ice out you'll be back in business.
Posted on Nov 08, 2010
  • tpmiller88 Nov 16, 2010
    We are having the same issue... We have defrosted the freezer and cleaned it all, but it starts to freeze as soon as its coming out. Is there a fix to this? Its only a few droplets that start to freeze. Should it be cleaned with something?? Alcohol? or could the freezer temp have something to do with it??
  • Jason Kennidy
    Jason Kennidy Nov 16, 2010
    Some models have what they call afill tube heater that actually goes around the tube, if its metal, to keep this from happening. I would call the manufacturer and see if this option is available. Also, if the problem persist, the water valve may not be closing properly after it fills the ice maker causing excess water to come up therefor freezing in the line. This is not a common problem problem but is a possiblity.
THE ICE MAKER PRODUCES LOTS OF ICE HOWEVER WHEN I PUSH TO DISPENSE ,ICE COMES DOWN THE SHOOT BUT DOOR WILL NOT OPEN TO RELEASE.tHE WATER FEATURE WORKS FINE ON THE FRIDGE .i HAVE REPLACED THE DOOR SEAL BUT...
There is a small motor on the outside of the freezer that you can see if you look up inside the door opening for the water and ice. It may be a silver color and is not very big. On a Whirlpool it is between the ice chute and the water outlet. Also, sometimes the ice chute door freezes shut.
Mar 25, 2015 | Maytag Refrigerators
Kenmore Elite side by side - Icemaker chute freezes up, no ice
To make sure I am understanding you correctly, are you saying that after a normal fill, water continues to drip into the ice maker and freezes in the fill chute?? If yes, than replace the water valve.
If not then:
does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Kenmore where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Kenmore and inquire about the aforementioned. If this is your case, there is a good chance they will cover it.
Goodluck,
Please don't forget to rate me as fixya..
Feb 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
Ice maker over flows
Not sure on this brand, but on some ice makers, there is an adjustment for the length of time the water the water runs down the chute. See if the ice maker instruction sheet is in the back of the unit - it may show where and how to adjust the time. Another idea would be to partially close the water valve that goes to the ice maker unit, so less water gets into the ice maker. However, over time, this will mean the valve will leak through when the valve is turned off. Good Luck
Feb 20, 2014 | GE Monogram ZDI15C Automatic Icemaker
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire ice maker water inlet freezing
its more than likely the water valve as they get limed up and leak past the valve seat,watch the tube depending how bad the leak is you will see a drip come down the chute every now and then,this is what makes the ice build up,you cant simply unplug the solenoid in the back to test because its not an electrical problem,the only other possibility would be too low or too high water pressure feeding the valves causing the leak,if on municipal water supply its probably not a cause, pressure needs to be between 15 and 120 p.s.i.
Aug 29, 2012 | Refrigerators
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
301 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
