Question about Hitachi 51F59 51" HDTV Projection Television
My screen is blurry on the bottom half of the screen, but the picture is still visable. What could be wrong?
Blurry & Fuzzy Picture Sony Trinitron
Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
Sep 28, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung TV HL55679W has a blurry bottom hslf picture
The set has either one or two boards for this---most have two boards and one drives half of the screen and the other the other half==a few combine both into one larger board.
Usually if only one half==that is the problem---in some cases it can be a defective screen unit-called a display panel which is fatal if the case as it costs more than the set did when new.
Jun 16, 2012 | Samsung Televison & Video
Old Panasonic tv approx 10/12 y/o? -Model TX-28CK1L Serial no ND-0360158 Last night 50% of screen from top to middle "blacked out"--half picture still visable on bottom half. Very bright thin...
The main coupling capacitor feeding the frame scan coils has failed or the output stage on the frame stage has failed due to dry capacitors or dry joints.
Fault finding and components are not a problem and yes it is very repairable. Any technician that knows how television works can repair this standard frame output stage.
I hope you find a good technician.
Dec 30, 2010 | Panasonic Televison & Video
My camera is taking blurry pictures and its blurry when u look at the screen
Have you checked the autofocus? You may need to clean the front sensor. Hold shutter down half way to see if camera will autofocus, try this in several modes. Hold shutter half way down and look at screen, picture should come into focus. Make sure you do not have "Macro" selected
Mar 02, 2010 | Cameras
Convergence problem
you may have shorted some thing out when you installed the new board
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Split screen
replace the main board inside the set.
Feb 22, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
1/2 the screen is blurry
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Toshiba 53HX71 53" Rear Projection...
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
Sep 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Mar 20, 2006 | NEC PlasmaSync 61MP1 61 in. Television
Hitachi 51F59 51" HDTV Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
