Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
How to change a cluth on a rancher 455 chainsaw
  • 7,733 Answers
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
How to change the fuel line on a Husqvarna 455 Rancher
feed a wire threw the tank cut the new hose down to 1/3 about 1/2'' long slide it over the wire and pull it back till it pops threw then pull it threw
Aug 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
How hard is it to change piston, ring, and cylinder on a 455 rancher chainsaw?
It is a full strip down, the cylinder makes up part of the crankcase and sandwiches the crank and main bearings, it is not a job for an amatuer, i can try to go through it if you wish to carry on with it.
Jul 26, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw will not shut off using stop, I have to use the choke to shut it off. Husqvarna 455 Rancher
the wire on the stop switch probably came of the terminal. take the top cover off 3 screws ,and the air cleaner. you just replug it.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 Rancher...
hi ,
by what your describing i think the chain brake has came on , you will have to reset this , its a good idea to carefully hold it in a vice and try to manually reset it
hope this helps
Jan 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
How do i remove the cluth drun on a husqvarna 455 rancher
Hi, first take off the clutch cover by removing the two bar nuts.
The nut on the clutch is left hand thread. You need to have some sort of piston stop to bind the engine when you remove the nut. They make tools just for that( it's called a piston stop) but I like using a small piece of rope. Just take out the spark plug, run a bit of the rope down in the cylinder and that will hold the piston really well. You could use a lof of things for that, I would be careful that it's something that won't gouge or mess up the top of the piston though. When you have that done you can remove the nut holding the clutch assembly on and remove the drum. ( REMEMBER that left hand thread ) Hope that helps you.
Jul 24, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
89 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
