Question about Dell Latitude D610 Notebook PC
Have a dell d610 and when i turn it on it does not boot. says bad command or file name. when i run a diagnostics test it says to insert a driver and utilities disk. what and where can i get one.purchased computer 2 yrs ago and havent used it before. i don't know how to get started. I am not to computer savy.
  • Dell Master
  • 1,443 Answers
Hello, If you didn't get any cd's with the computer and you didn't make any cd's from the system maintenance program then is sounds like you will have to take your computer to a repair shop. You either had a bad hard drive or your operation system software is corrupt and will need to be reloaded.
Please rate my answer, Thank you.
Posted on Nov 04, 2015
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Dell "Drivers and Utilities" CD
Hi, the "No Diagnostic Utility Partition Found" is returned because your laptop does not find the recovery partition on C drive.
Easiest way to create partition is with dell recovery cd. You can buy CDs from dell, buy finding contact on web site or buy from one of the following.
Dell Restore Disk: XP Pro SP2 for ... $35.00 - DIMOSOL - Digital ...
Dell Latitude D600 XP System Recovery CD ... $18.95 - recovery-cds.com ...
Dell Latitude D600 Vista System Recovery ... $18.95 - recovery-cds.com ...
Buy recovery cd according to windows version on sticker at the back of your laptop.
With recovery CD you wont need drivers.
Alternative solution is downloading drivers posted by Maanita after installing Windows from a generic Windows setup CD.
Posted on Aug 13, 2008
SOURCE: no diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Posted on Sep 01, 2012
Internal hdd hard error
Using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
Will your assistance cost me anything? I turn the laptop on, the DELL word shows on the screen, and then the screen goes BLANK (cursor line shows at the upper left hand side of the screen). There is an...
This is a freebie
The system is not booting to the hard drive, the #9 indicator is an indication that the number lock is enabled.
Try holding the Fn key while powering on the system, see if diagnostics run (The works on newer Dells, not sure about the D610) If you don't have that function, if you have the resource cd, try and boot to it and run diagnostics.
Generally, the issue you describe is a problem with the hard drive, if it passes diagnostics, then see if you can repair the windows install booting to the XP Cd
Jul 08, 2011 | Dell Latitude D610 Notebook
When I start up my Dell Latitude D610, it will go throught the boot sequence, and imediatly after the microsoft windows XP loading screen is shown, a blue screen apears that goes by too quick to read. Then...
Pressand hold the key while powering the system on. This will run theDell Diagnostics. Another more intense diagnostic program is located on a DellCD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed underthe "Contents". You will have to boot from that CD disk. To do this, power onyour laptop and tap the key to bring you to the "One time bootmenu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the 32 Bit DellDiagnostics". If the laptop runs the diagnostics without errors then you have a software issue. If it is a hardware issue (i.e. memory,hard drive) diagnostics will indicate faulty component.
Feb 21, 2011 | Dell Latitude D610 Notebook
My dell latitude D610 does not hibernate. the option is there but it does not work.
fix ur os errors with reg in out registry cleaner and then do this Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files.
Sep 21, 2010 | Dell Latitude D610 Notebook
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
you might have jarred the memory loose. take it to a local technician to have them check it out.
Oct 10, 2009 | Dell Latitude D610 Notebook
NO BOOT SECTOR ON HARD DRIVE
Afraid you are going to have to get ahold of a copy of the Dell operating system. Once you get that loaded, you can go to www.dell.com to download/install all of the device drivers.
You can actually use any retail operating system version, does not have to be dell. It is only that the dell copy is less expensive. You might try getting that on Craigs List or Ebay.
Good Luck
Mar 17, 2009 | Dell Latitude D600 Notebook
Will not boot to Safe Mode
Try to boot from the Resource CD by selecting the <F12> key and select boot from CD/DVD drive. If you tried to run the "Diagnostics" option from the <F12> boot menu and it went to command prompt, there might be an issue with your hard drive or the "Diagnostics" partition is corrupted or missing. If all tests pass using the Resource CD, then your OS is probably hosed. As for the 9 LED light, that just indicates that your numeric keypad is enabled.
Oct 17, 2008 | Dell Latitude D510 Notebook
Dell Latitude D610 Notebook PC Logo
107 people viewed this question
Alun Cox
